Thread: Engine managment light???????
    Jul 2009
    hertforshire
    Default Engine managment light???????
    Hi,
    has any one had the problem with the spanner light comming on when its cold......?
    Every morning or if the car has been stud, when its started the spanner light stays on if i turn it off and start it again, it goes off and i never see it again (untill the next morning). i have no idea what it could be and its ony started doing it recently.??? but the alarm started playing up at the same time as light ???
    any ideas ?
    Nov 2007
    North Wingfield, Chesterfield, Derbyshire
    Vehicle : Vectra C Hatchback Facelift
    Trim : Club
    Engine : Z18XE
    Mileage : 100085
    You might try a fault code reader...or the Brake accelerator pedal trick of reading/identifying fault code....depends on what engine petrol/ diesel and model year...several posts on here on similar problems....try search section...cheers
    11 Post(s)
    OP's public profile says he's got a SRi 150. Guessing that's a CDTi 150, in which case previous posts on here have suggested that the glow plugs are on their way out.
    West
    I'd agree with above have the glow plugs or pre heat system checked
    Regular Member phykell's Avatar
    Apr 2008
    Cheshire
    Mine's doing exactly the same. Luckily, it's booked in for its annual service this week so I'll let you know what they say.
  1. Engine Managment Light Help
    By Telboy in forum Vectra C / Signum Car Chat
    Last Post: 5th July 2011, 00:10
  2. engine managment light
    By patch22 in forum Engine & Drivetrain
    Last Post: 22nd June 2011, 22:52
  3. Engine Managment Light
    By zealot210 in forum Vectra C / Signum Troubleshooting
    Last Post: 30th June 2010, 11:58
  4. Engine Managment Light, Help!!!!
    By whatthevecisup in forum Electrical & ICE (including SatNav)
    Last Post: 12th April 2008, 22:29
  5. engine managment light?
    By tonytaxi in forum Electrical & ICE (including SatNav)
    Last Post: 20th June 2007, 07:38
