Results 1 to 10 of 15
Thread: Tire pressure sensors. How to reset or something?
    Full Member Lao's Avatar
    Aug 2009
    Romania, E.U.
    Vehicle : Vectra C Estate Automatic
    Trim : Elegance
    Default Tire pressure sensors. How to reset or something?
    Hi everyone!
    I recently switched the front wheels with the back ones. On one of the back wheels I don't have a sensor anymore due to an accident. By the way, I'm still searching for a decent priced sensor.
    The problem is that after I put the sensor-less wheel in the front, the computer still shows as it's on the back. Practically it says that the rear left wheel's pressure can't be read. In fact, the wheel is now on the left front side.
    Is there a way to reset them? Maybe with Tech2? It must be a way other than switching the valves between the wheels, right?
    Thank you.
    Lao.
    Administrator plasma's Avatar
    On the Forum
    399 Post(s)
    Engine : 150
    Mileage : 74000
    Tech2 can get them to relearn them from fresh, only way to do it as far as i know
    WGAF#5
    each tire sensor is programmed in sequence and is learnt in position so if you move them around they will give you a false reading- we get customers in with readings being given from the "spare wheel well" saying that the front tire has low pressure-puncture as the sensor is still transmitting even though its been swapped out -
    regarding your link to a search for a tyre sensor - you would be better posting a new request as the link shows that the request is attached to a thread in the photo section - so no one will know until they have read the whole thread and page 5
    Mar 2007
    Tamworth
    Only a car manufacturer could design/fit a component that needs expensive dealer work EVERY time tyres are rotated (as recommended) and EVERY time new tyres are fitted.
    I don't know what the current minimum rate is for a Tech 2 session, say £50, which would be £1/week just on tyre pressures - cheaper to DIY with a digital gauge.
    Whatever happened to the earlier system where continuous differences in ABS sensor rotation was used to indicate a tyre pressure problem?
    Aug 2009
    Romania, E.U.
    Trim : Elegance
    So, in conclusion, Tech2 would solve this issue, right?
    @ deztroyer: I can't post in the "Parts wanted" section unless I'm a full member.
    The search for a sensor continues HERE.
    I have a friend who can Tech2 my car for 10 GBP, but if this might seem cheap to you, for me it isn't.
    Devon
    77 Post(s)
    Vehicle : insignia
    Trim : irmscher
    Quote Originally Posted by Ruperts Trooper View Post
    Don't think that's true as when you 1st setup the sensors you put the tyre pressures in for front and back so the sensors are set but afaik if you fit a new sensor it doesn't need to be tech2'd to the system
    Irmscher Insignia CDTI 130
    Mar 2007
    Tamworth
    Quote Originally Posted by bigmac View Post
    What happens when you temporarily increase tyre pressures for a heavy load and then drop to normal afterwards, does that give a warning all the time - or indeed just switch front-back.
    Devon
    77 Post(s)
    Vehicle : insignia
    Trim : irmscher
    I'm sure it only warns when tyre pressure drops indicating a puncture
    Aug 2009
    Romania, E.U.
    Trim : Elegance
    Mine indicates the real pressure in each tire.
    Devon
    77 Post(s)
    Vehicle : insignia
    Trim : irmscher
    Quote Originally Posted by Lao View Post
    Yes but you only get a warning when it drops below a pre set limit
    BTW....What Stereo have you got ?
  1. tyre pressure sensors
    By rozzer2006 in forum Electrical & ICE (including SatNav)
    Last Post: 29th October 2012, 21:53
  2. Tyre pressure sensors
    By Chuddy in forum Suspension, Wheels & Brakes
    Last Post: 1st August 2009, 22:50
  3. tyre pressure sensors
    By marc7 in forum Vectra C / Signum Car Chat
    Last Post: 8th May 2009, 21:42
  4. Tyre Pressure Sensors??
    By rustywheelnut in forum Vectra C / Signum Car Chat
    Last Post: 11th April 2007, 00:06
  5. What is the standard tire pressure
    By Bigair in forum Suspension, Wheels & Brakes
    Last Post: 2nd May 2006, 08:49
vauxhall insignia tyre pressure sensor reset
vectra c problem with pressure in tires
opel vectra c 2005 wheel air pressure display
how to reset tyre pressure on vauxhall insignia
vectra c tpms reset
vauxhall adam tyre pressure monitor reset
vectra c reset tpms
opel astra tyre pressure light reset button
vectra c reset tyre pressure
how to reset tire monitor system on 2010 insignia
signum reset tyre pressure
unde este calculator tpms vectra
insignia tpms reset
tyre learn vauxhall adam
Opel adam tyre pressure sensor
vectra tyre pressure sensor
vectra tpms
how to reset tpms sensors vecta c
vectra c tyre pressure warning
service tyre monitor system reset vauxhall insignia
air pressure problem. vectra
opel signun tire presure
opel insignia resetare TPMS
sparovani tpms vectra
opel vectra c tyre pressure not shown
