Thread: Replaced thermostate, but cold inside...
    May 2007
    Norway
    Default Replaced thermostate, but cold inside...
    Hi
    Today I replaced the thermostat in my Veccy 2006 1.9CDTI, and the engine-temp is back in the range of 84-90 degrees during normal driving. (it was only 75-79 before the change) So far so good.
    But, there is no heat in heating-system inside the car now.
    Perhaps this is beacuse there are some air trapped in the lines, but I cannot find any place to went it out....
    Any suggestions, trix?
    Thank you.
    Regular Member benny's Avatar
    Feb 2006
    dudley
    did you bleed it via the bleed screw ? ...
    jilava
    the bleed screw is on a metal pipe in front of engine central position. I found out you need to bleed several times to get all the air out.
    May 2007
    Norway
    Aha, I have seen that pipe and that little bleed-screw, but I did not think it was so tightly connected to the heater inside. I opened that one when I re-filled the tank with coolant, but it must be bled several times...... Okidoki.
    Thanx guys!!!!
    Jul 2009
    barnsley,yorkshire,GB
    Engine : 20 Dti
    as andreitone says,but if you still have problems overfill compensation tank to top of neck and open quick connector in heater line (left one facing forward)then as A says again
  1. random cold knock/tick sound when cold - 1.9 cdti
    Last Post: 18th January 2013, 18:59
  2. smoke at cold cold start
    By azacbr6 in forum Engine & Drivetrain
    Last Post: 5th December 2012, 18:23
  3. What do I need replaced
    By m20_swe in forum Engine & Drivetrain
    Last Post: 25th March 2012, 08:45
  4. Thermostate + egr = common link ?
    By roswell in forum Vectra C / Signum Car Chat
    Last Post: 26th January 2011, 04:31
  5. maf replaced still need help
    By scutster in forum Engine & Drivetrain
    Last Post: 15th May 2010, 10:16
