Results 1 to 3 of 3
Thread: first cam belt changed
    Regular Member kdadidog's Avatar
    county durham (peterlee)
    Default first cam belt changed
    as above. I had my cam belt changed for the first time as I the car has 50000 miles on it now and is 6 year old. While I was needing the cam belt kit I also thought to replace the water pump as it was mensioned a few times on forums. So thought I may as well change the oil and filter as I only had new plugs about 8000 miles ago and bought a K&n panel filter shortly after the plugs. So all together I did: cam belt kit, water pump, halfrauds 5/30 gm grade oil, oil filter. my mate is a mechanic and did it all with a total cost of £160 including parts and labour. well pleased as the kit is a genuine GM kit.
    Sep 2009
    Swindon
    wow that is really cheap, I did my cam belt and water pump myself and the kit/waterpump cost me £150 supply only from VX, how did you get it so cheap?
    Frenchman
    Quote Originally Posted by frenchman View Post
    Frenchman
    bought the water pump for £21 at local motorfactors then bought a timing belt kit from,,,,,EBAY. at a cost of £55. then the oil was £38 and filter was £2. £40 was what I paid for the fitting and his time.
  1. need timming belt changed anyone up for it??
    By rozzer2006 in forum West Scotland RO - Mr Gee, ARO - RBH
    Last Post: 24th October 2012, 10:48
  2. How can you tell if a timing belt has been changed?
    By Caveman_nige in forum Vectra C / Signum Car Chat
    Last Post: 21st January 2012, 10:19
  3. ok...changed timing belt and.....
    By Big Knox in forum Vectra C / Signum Car Chat
    Last Post: 8th April 2011, 16:31
  4. Cam belt changed at last...!
    By si_sri in forum Engine & Drivetrain
    Last Post: 4th July 2010, 19:16
  5. Cam belt - is there a way to tell if it's been changed?
    By andreitone in forum Engine & Drivetrain
    Last Post: 29th August 2009, 17:26
