Results 1 to 10 of 14
Thread: Clutch pedal noise
    Sep 2009
    Glasgow
    Default Clutch pedal noise
    Hi all getting noise from clutch pedal just about when I return it to start position, there is no vibration or judder it's not a mechanical noise sounds more like a creaking door and all is well with the car running, when im in start stop traffic with passangers i need to have the radio on as it sounds as if were in a creeking bed, bit embarassing Think it might need some lube.
    Regular Member smiley-sri's Avatar
    Jul 2009
    Tamworth
    I had this problem on and off for a week and it got VERY VERY annoying. In the end I got in a huffy
    It really piddled me off so I put my foot flat on the floor,,,,knocked the traction control off and spun the wheels. Yes I Know.....very childish.
    Its never dont it since and that was 3months ago....
    Jul 2009
    Tamworth
    My car had this problem and I was pulling my hair out trying to figure out what it was. In the end I lost my temper
    I turned the traction control off put my foot on the floor and said bye to the clutch pedal.....Yess very childish indeed
    It sorted the problem out though. Sinse I done that never heard it again.
    Obviously I wouldnt recommend doing this, but, hmmmm. Weird one. And im sure if you took it to vauxhalls they would want to strip the clutch to bits. This is what i was worried about.
    BILLS
    Worcs/Staffs/Westmids (ish)
    Im not sure how turning the TC off and driving like a loon is going to stop a squeaky clutch
    First of all, is the noise inside or outside?
    Sep 2009
    Glasgow
    inside, used the car about 20 min ago and no noise, it comes and goes.
    Regular Member vxr-i-wish's Avatar
    Nov 2009
    Quarry Bank, W.mids
    think its a common vauxhall clutch pedal squeak!! Ive had it on all my vauxhalls. You can give it a spray with wd40, will go away for a while, but will return.
    Quote Originally Posted by vxr-i-wish View Post
    That's because WD40 isn't a lubricant, it's more of a solvent (50%+).
    Anyone who's ever used it on a bicycle chain will atest to that, because it removes grease (which is factory fitted inside the chain rollers) and you get the classic squeaky chain.
    Don't get me wrong though, it's ****** brilliant for displacing water and breaking down rust. As well as being one of the few recommended carb cleaners on the market.
    Get something thicker, something that sticks and you'll be fine. Spot of grease wouldn't hurt. In fact, you could probably use a spot of engine oil and do a better job than WD
    Sep 2009
    Glasgow
    had a look at the clutch pedal, it has a spring on it, assuming that is where the creaking is coming from as it only has a tiny bit of grease on the top of it and the rest of it looks dry, i have a product called carlube lm2 multi purpose grease lithium based will this be ok .
    Quote Originally Posted by nokiaman1978 View Post
    Only one way to find out
    Sep 2009
    Glasgow
    helped a bit by putting grease on it but there is still a creaking noise from the pedal.
  1. clutch pedal really soft after new clutch
    Last Post: 3rd February 2013, 14:52
  2. clutch noise when pedal depressed
    Last Post: 22nd October 2012, 23:19
  3. Clutch pedal noise
    By danno in forum Vectra C / Signum Troubleshooting
    Last Post: 11th October 2010, 13:14
  4. clutch pedal
    By Tam80 in forum Engine & Drivetrain
    Last Post: 2nd September 2010, 19:41
  5. Clutch pedal
    By old cruiser in forum Vectra C / Signum Car Chat
    Last Post: 8th July 2008, 23:53
vauxhall insignia clutch pedal clicking
insignia creaking clutch pedal
vauxhall insignia squeaky clutch pedal
vauxhall insignia clutch pedal noise
how to fix squeaky clutch pedal vauxhall insignia
sticking clutch pedal insignia
opel insignia creaking sound on the clutch pedal
clutch pedal return spring on Vauxhall Insignia
opel insignia sound on the clutch pedal
2010 vauxhall insignia clutch pedal clicking
clutch clicking insignia
insignia clutch pedel c
vectra c creaking pedal
squeaky clutch pedal Astra sri
vauxhall insignia clutch pedal new
knocking sound on clutch pedal of opel igsigni
my vauxhall insignia noise when i place cluch pedal
insignia 09 vibrating clutch
vauxhall insignia noise from clutch
why does my vauxhall insignia clutch pedal make a noise
noise from clutch pedal opel insignia
