Thread: Alternator upgrades??
    Regular Member smiley-sri's Avatar
    Jul 2009
    Tamworth
    Exclamation Alternator upgrades??
    Righto.....Im struggling to power my jbl14001 amplifier using the vectras standerd charging system.
    I have done the big 3 upgrade and I am now looking at upgrading with a liesure battery in the boot.
    The system is currently pulling 1500wrms.
    Before i battery upgrade....Are there any alternators i can fit that would fit without too much modification.>
    Maybe ones from vauxhall vans or other engines?
    My engine is a 2005 '55' 1,9cdti 120 8v
    Am i right in thinking that its standerd alternator is 105 or 120 amp?
    So what is there better than this?
    Are you VXR Enough
    13 Post(s)
    Engine : 6.0 V8 Thunder
    you could try a 140 amp but i dont know if it would actually fit but they are expensive over £400
    Mar 2007
    Tamworth
    Fit a second battery, but don't use a leisure battery - at 1500w, you'll be pulling 125A continuously which is way too much for an ordinary leisure battery - they may be good at deep discharge but always at an amp-rate under 10%, preferably under 5%, of the amp-hour capacity - where are you going to find a 1250-2500Ah battery? Use a marine battery, eg Numax CXV, with as high a CCA/MCA rating as possible (MCA is always CCA x1.25) - this will handle high current drain much better.
    With the proper second battery, the standard alternator will probably cope although a gently-driven autobox will struggle because the engine revs are always kept low.
    Jul 2009
    Tamworth
    CCA is the max amp it can give out for a peroid of time. If i get a battery caperble of 900~CCA but its only 44ah...then it will provide plenty of power for a quick play.
    It will discharge the current quick enough for a dump but will run out of steam playing full tilt very quickly.
    If I get a liesure battery with 110ah but with a CCA of 350 it will still provide plenty enough power for a big draw of current. And play for alot longer.
    Remember I will still have the alternator attached to this.
    Regarding the alternator.....eventually I will be upgrading again, again, again and again.
    So some where along the line i Will end up with a good few batterys in the spare wheel hold but still a 100amp alternator which will charge them. But will take a rather long time,
    most of the people with big systems on the audio forum I use have upgraded there alt to 220amp and higher.
    Also if I get a big alternator under the bonnet it will save me having to have a battery in my boot.
    If 2 very good batterys are going to cost me £300. I can get an alternator of ebay cheaper.
    Would i see much difference going from 105/120 ( anyone know what mine is) going to 140amp...Im sure you could get one on ebay around £150 used..
    Although £150 seems expensive for 35, maybe 20amps.
    Is there no other alts of different engines, models etc etc
    Mar 2007
    Tamworth
    http://www.tayna.co.uk/Numax-CXV30HMF-P3672.html
    113Ah - MCA 1000A - £96 incl delivery - any good?
    Jul 2009
    Tamworth
    I was going to get one off ebay......much much cheeper so my money will go further.
    There must be alternators out there that fit. Who are the alternators made by?
    Jul 2009
    Tamworth
    BTTT Sorry
  1. What upgrades
    By militis in forum Vectra C / Signum Car Chat
    Last Post: 22nd January 2013, 12:43
  2. two more upgrades done
    By nph1 in forum Vectra C / Signum Car Chat
    Last Post: 1st May 2009, 11:15
  3. Upgrades Available
    By Cragy in forum Vectra C / Signum Car Chat
    Last Post: 25th January 2008, 18:23
  4. AFL Upgrades
    By Stu14t in forum Electrical & ICE (including SatNav)
    Last Post: 21st October 2007, 12:07
  5. more upgrades done
    Last Post: 25th May 2007, 14:41
vectra c upgrade alternator
