Thread: DAB Box quick question
    Nov 2009
    leeds
    Default DAB Box quick question
    just about to connect up my dab box to my cdc40 just wondered if the brown cable coming from the dab unit is negative and the red is 12v live?
    Regular Member Robsey's Avatar
    North East Cheshire
    23 Post(s)
    Trim : Energy
    Mileage : 131,000
    If the wire is plain brown (no stripes) then this is indeed ground / Chassis / Earth
    Red is permanent 12 volt supply and Black if you have one is for ignition live.
    Nov 2009
    leeds
    i have a red and brown cable which will be 12v live and earth. then theres green/white twisted together which goes to the display plug and 2 black cables which have 2 wires inside them which are connected to the ones on the cdc40 plug.
    North East Cheshire
    23 Post(s)
    Trim : Energy
    Mileage : 131,000
    right your wires are as follows : -
    green - to GID display pin 17
    white - to GID display pin 18
    red to +12 volts
    brown to 0 volts / ground
    green with brown stripe to CDC40 pin 31
    blue with red stripe to CDC40 pin 32
    unknown colour (shield) to CDC40 pin 38
    hope that helps
    North East Cheshire
    23 Post(s)
    Trim : Energy
    Mileage : 131,000
    note there are two shields that are linked together and then run to pin 38!!.
    one from each black shrowded pair.
    the red goes to fuse FI1 - 20 amps at the end of the dash. same as the radio.
  1. quick question
    By scottyd in forum Vectra C / Signum Car Chat
    Last Post: 7th August 2011, 21:39
  2. Quick Question - Need a Quick Answer if Possible
    By RobW in forum Suspension, Wheels & Brakes
    Last Post: 8th February 2011, 23:55
  3. Quick Question
    By Perry in forum Vectra C / Signum Car Chat
    Last Post: 10th October 2008, 22:14
  4. A quick question
    By Maverick in forum Vectra C / Signum Car Chat
    Last Post: 13th May 2007, 14:53
  5. One Quick Question.....
    By Maverick in forum Irmscher Factory Road Trip - 13-16th April
    Last Post: 11th April 2007, 12:03
vectra DAB box
