Thread: Damn Gearbox again....
    Apr 2008
    sheffield
    Default Damn Gearbox again....
    Hi
    After spending around 1300 quid fixing the dreaded water in the oil problem with my 2.2 dti's auto box, the car has been running fine. The garage also converted it to make sure that the problem doesnt occur again.
    However I did notice it tended to stick in 1st or second gear for a bit to long, but thought that was the nature of the car. Anyway near the 1 year mark since the problem was fixed I noticed that it was beginning to stay in 1 and 2 for longer and longer, espcially when first starting up.
    Anyway took it back to the garage and the computer they had could find no faults other than the mass airflow meter was knackered. So I had that changed it it started to behanve better.
    However everytime it is first started, i.e when going to work in the morning, it just struggles along stuck in first or second gear. Its getting really annoying, going 15 miles up the hill near my house towards work with fuming drivers behind.....
    p.s once warm she runs spot on.
    Any advice please?
    Regular Member Lao's Avatar
    Aug 2009
    Romania, E.U.
    Vehicle : Vectra C Estate Automatic
    Trim : Elegance
    1. Change gearbox oil, 2 times. Every time you will change ~ 2.8-3 liters. That's the reason you have to change it at least 2 times, minimum 80-100 miles between the changes.
    2. Warm the car a little longer before driving. 4-5 minutes with the engine running will do good things. Gearbox in D, foot on the brake.
    That's all I can think of for now.
    EVERYWHERE
    Try resetting the ECU again, and then drive like your grandad for a few days.
    Because I think the A33 Auto box is of the 'adaptive' type?
    It may be that your driving style (fast getaways?) causes the auto box to hang on to the lower gears for longer than necessary. This is something that 'adaptive' gearboxes do over a period of time. They can be a real pain in the butt, particularly if people driving the car have different driving habits. Ask any auto driving instructor about problems with 'driveabilty' when they drive the car! LOL
    Regular Member Celes's Avatar
    Slovenia, Koper
    Vehicle : Opel Signum
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    That's "warm-up" mode. Mine is a bit annoying too, but nothing like yours!
    As suggested, reset the ECU.
    Apr 2008
    sheffield
    Quote Originally Posted by diesel dog View Post
    Hmmm oddly enough just after the box was fixed, my wife suddenly had the urge of starting her driving lessons again, and I have to say that probably most of the first 100 or so miles after being fixed were done by her ( a learner at that stage).
    Apr 2008
    sheffield
    Quote Originally Posted by Celes View Post
    Think I will try this tonight. P.s is it a simple case of removing the battery for a while to reset the ecu?
    Regular Member Eirik's Avatar
    Aug 2009
    NORWAY/Kristiansand
    I'm just curious, what did they do to make sure that the problem doesnt occur again?
    Fit an external oil-cooler or just a new radiator?
    Apr 2008
    sheffield
    Quote Originally Posted by Eirik View Post
    Basically the gearbox oil was cooled by going through the radiator, which in time would start to leak etc......
    The solution is an external oil cooler, so therefore bypassing the cars radiator. Something Vaux should have done to begin with. Cost me abou 1300 quid. Far cheaper than the dealers quite of a new box for 3000 something....
    Aug 2009
    NORWAY/Kristiansand
    Ok, i have been thinking to do the same with mine, but i will do it before it fails!
    That was cheap for the box, here in Norway i have heard rumors that the box is more like 6000+
    It hapend with my granddad's 2.2i, he had to replace the box, luckily the insurance covered it!
    Apr 2008
    sheffield
    Very good idea. I would advise all owners do this before its too late.
    p.s and sooner or later the damn thing will leak!
  1. M32 gearbox can`t get gear selector back in gearbox HELP!
    By v33tra in forum Engine & Drivetrain
    Last Post: 30th March 2017, 07:43
  2. Damn Car!
    By Torque in forum Engine & Drivetrain
    Last Post: 21st February 2011, 19:06
  3. Dry damn you dry!
    By nutron in forum Vectra C / Signum Car Chat
    Last Post: 14th April 2007, 01:26
  4. Damn PVS........
    By The Doc in forum Vectra C / Signum Car Chat
    Last Post: 15th May 2006, 17:48
