Results 1 to 10 of 18
Thread: Rear Brakes
    Aug 2009
    Bristol & Stockton on Tees
    Default Rear Brakes
    My 2008 Vectra Elite 1.9CDTi has done just over 30000 miles, mostly on the motorway. To my surprise I heard the rear brakes grinding when slowing down on a motorway slip road, costing me new discs and pads !
    The work was carried out by my local Vauxhall dealer (£193 inclusive of Trade Club discount on parts) and the Technician showed me the offending pad (O.S.R. inner pad) that was completely down to the metal.
    I have had loads of cars but never one that wears out its rear pads before its front pads - so be warned !!!!!
    The rear tyre rumbling is also starting again after new tyres were fitted only 3000 miles ago.
    I am starting to go off this car.
    West Lothian
    Had the same happen to my '57' SRi 150 last month at 29,000 miles. It was the exact same pad that was down to the metal.
    The other 3 pads still had about 2-3mm of material still left.
    The car was only serviced in July (at 26,000 miles) and the garage reported all pads to be fine. The garage was Arnold Sharks, so might not be such a suprise.
    I will be keeping a close eye on the wear of the rear brakes from now on.
    That's a shocking price for just new pads and discs mate. Granted I do my own work in that area but considering the cost of the pads and discs themselves that really is extortionate...
    Regular Member wardy's Avatar
    Chichester
    seems a common thing on the vec. My old 3.0 had rear pads replaced at about 40,000, front ones went on to 50,000. I queried it on here at the time, and it seems to be very common.
    Regular Member nick_s's Avatar
    Jul 2009
    Stoke on Trent
    Anyone know what the brake bias is on the Vec C's?? Could this have any bearing on the wear?
    Regular Member In a states's Avatar
    Dec 2005
    In an estate car
    I replace mine every winter...pads and discs should be around £60 for 292mm ones in a trade club....fitting extra of course.
    Aug 2007
    Leicester
    can confirm the same with me - 45k miles and had grinding from rear wheels, diagnosed as new discs and pads needed for back.
    Now 70K motorway miles and fronts still original.
    2.2 Direct Hatch 57 plate. Vaux dealer did mine and said it is common issue, but didn't know why. I wondered if it had to do with the handbrake causing the pads to run a bit too close to disc. Adjusted up a bit high from new possibly?
    Regular Member Jezzy's Avatar
    May 2009
    S.E
    Quote Originally Posted by In a states View Post
    Nah, fitting isn't extra...it's a DIY job.
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Mileage : 137000
    Quote Originally Posted by nick_s View Post
    The rear pad is tiny compared to the fronts even on 285 set up, so they wear much faster. I change my rears every MOT but i'm only on my second set of pads on the front. (62000 miles.) I've found the main problem is dirty slider bolt shafts, I clean and lube them up every time, this seams to help the outer pad wear about the same as the inner.
    Jul 2008
    VXR where are you now
    16 Post(s)
    Trim : Nissan GT-R R35
    Engine : 3.8 twin turbo 700hp
    is the brake bias valve adjustable
  1. need help for rear brakes
    By sharney2011 in forum Vectra C / Signum Troubleshooting
    Last Post: 8th October 2011, 18:20
  2. rear brakes
    By johnytaff in forum Suspension, Wheels & Brakes
    Last Post: 4th March 2011, 19:33
  3. Rear brakes
    By copperdock in forum Vectra C / Signum Car Chat
    Last Post: 12th March 2008, 22:50
  4. scraping noise from rear. rear brakes? upgrade?
    By Whippy in forum Suspension, Wheels & Brakes
    Last Post: 5th March 2008, 01:26
  5. Rear brakes
    By dan1983 in forum Suspension, Wheels & Brakes
    Last Post: 22nd May 2007, 21:09
