Thread: Anyone changed the belts on a 1.8 vvt?
    Regular Member PeterVV's Avatar
    Oct 2007
    south wales
    Default Anyone changed the belts on a 1.8 vvt?
    Is it any easier / cheaper to do than the normal cam belt?
    Is changing the water pump any easier as its not on the cam belt?
    Oct 2007
    south wales
    Anyone?
    Oct 2007
    Shropshire
    No but I'm interested - I should do mine, its only done about 20k but i swapped the n
    engine and i think the one i put in had sat unrun for ages....
    Regular Member benny's Avatar
    Feb 2006
    dudley
    water pump is external and i would say dont need replaceing .....plus you only really need todo the cam belt on the 18xer the rollers apear to be good on these engines ...
    Jul 2009
    sussex
    i need to do my 1.8 non vvt soon. im asuming that they are essentially the same in this respect?
    Oct 2007
    Shropshire
    I'm not sure it is the cam pullies that do the variable timing, so i should think this would be one area it would be different!!
    Feb 2006
    dudley
    the 1.8 xer (vvt) is totally different to the earlier z18xe ....the early engine needs a cam belt kit fitting and a water pump beeing as it is driven via the cambelt ....
  1. CIM CHANGED NEED TECH2 in OXFORD AREA HAS ANYONE CHANGED A CIM BEFORE?
    By vectrasimonsri in forum Electrical & ICE (including SatNav)
    Last Post: 10th July 2011, 20:43
  2. Cam belts
    By SRIRob in forum Vectra C / Signum Car Chat
    Last Post: 4th January 2010, 23:01
  3. Belts
    By bgm46 in forum General Chat
    Last Post: 29th January 2009, 09:56
  4. Belts
    By jamesr in forum Vectra C / Signum Car Chat
    Last Post: 24th April 2008, 23:02
  5. Belts?
    By Stevie-B in forum Vectra C / Signum Car Chat
    Last Post: 29th June 2007, 13:42
