Thread: floppy gearstick!
    West Midlands
    Default floppy gearstick!
    Hi
    For some reason when in gears 1 to 5 there is a lot of left/right play in the gearstick.
    In reverse it is fine with no play at all.
    What do I need to check/tighten/replace?
    Regular Member ghostrider's Avatar
    On another planet
    Vehicle : 2.0l CDTi Bi-Turbo Insginia Sports Tourer
    Trim : Vx Line Nav Sri
    Engine : 2.0
    Interested in this one myself as mine has a little play in it too.
    West Midlands
    can anyone help?
    Regular Member P3tchy's Avatar
    Milton Keynes
    Sounds like the cables are worn, there's 2 that go to the gearbox to select the gear, either that or the bushes at the bottom of the gear leaver. They are plastic so do wear out if not greased.
    Regular Member denzilbud's Avatar
    cambridge
    there is a rubber washer that sits round the collar of the gear stick which snaps and comes out i just pushed the ring on mine back in the collar and ive never had any more problems
  1. vxr gearstick
    By toughmat in forum Styling
    Last Post: 1st April 2012, 22:40
  2. Vec-C Gearstick into a Vec-B?
    By Vaux-Man-G in forum Vectra C / Signum Car Chat
    Last Post: 14th November 2008, 09:50
