Results 1 to 10 of 24
Thread: very little air coming out of vents
    exeter
    Default very little air coming out of vents
    please can anyone tell me how do i get to the heater box behind the dash on my 53 vectra .? because vauxhall said it would be about £1300 to sort it out . the motor works fine but there is very little air coming out the window vent even on full please help
    Regular Member carpet's Avatar
    Jul 2006
    TENTERDEN KENT
    Have you tried pushing the button with the snowflake on it as this sets all the flaps and directs all the air up to the windscreen. As you push it you can hear the flap motor altering the flaps from the previous setting. If this provides you with plenty of air I would check the three motors. Put ignition on but do not start the engine, alter the left rotory control and you should be able to hear the motors operating the flaps. Do the same with the centre one, the right hand one is the fan speed. Hope this helps.
    Mileage : 000
    If you remove the glove box you can see the heater motor. This is what it looks like when the glove box is removed. I don,t know if it is any help to you though.
    http://www.vectra-c.com/forum/showpo...36&postcount=5
    Mar 2007
    Tamworth
    Check that the pollen filter isn't completely blocked.
    Full Member Big Sig's Avatar
    Quote Originally Posted by carpet View Post
    No it doesn't, that puts the A/C on.
    Regular Member gsi3.2Daveyg's Avatar
    Nov 2009
    Preston
    You know what carpet meant, the defrost button reeseandellie
    Quote Originally Posted by gsi3.2Daveyg View Post
    I know what he meant, however does everyone else?? You can see the misunderstandings that can happen from simple mistakes. maybe you should too rather than at me!
    Nov 2009
    Preston
    now big sig, didn't see in your post you telling anyone about the simple mistake ... maybe i missed it...i'll look again....no nothing...
    Jul 2006
    TENTERDEN KENT
    I am sorry that I seem to have started a row :-( it is in fact the top right hand of the four small buttons on the heater panel, that will teach me to check and not trust my failing memory. Now kiss and make up!!!!!!!
    Regular Member chris1804's Avatar
    Oct 2009
    Sandwell
    mine seems to only work on 2-3-4 not 1 when i put it on 1 i cant feel any air,
  1. Ford Ka - hot air coming from vents on all settings
    By Caveman_nige in forum The 'Off Topic' room
    Last Post: 3rd September 2012, 00:27
  2. face lift chrome vents and rear vents
    By simon1 in forum Vectra C / Signum Car Chat
    Last Post: 21st December 2011, 21:13
  3. Vents
    By Tam80 in forum Bodywork & Interior
    Last Post: 9th April 2011, 11:14
  4. smoke/dust coming from air vents
    By adfrodsham in forum Bodywork & Interior
    Last Post: 16th May 2009, 14:41
  5. Gid with vents
    By Dunc in forum How much is it worth? (THIS SECTION IS NOW CLOSED)
    Last Post: 4th February 2009, 12:16
