Thread: What to use to lubricate plastic gear linkage parts?
    Nottinghamshire
    confused What to use to lubricate plastic gear linkage parts?
    I've dismantled my centre console at the moment due to the airbag ECU needing replacing.
    While it's in bits, I want to lubricate the gear linkage/selection mechanism underneath the gear lever. It's made of white plastic and I can't find anything suitable.
    You can't use anything based on petroleum distillates on plastic unless you know the plastic is oil-resistant which I don't. That rules out pretty much all lubricants I've found including white lithium greae which was my first thought.
    Any ideas anyone?
    Mileage : 000
    What about a silicon based lubricant.
    Nottinghamshire
    Quote Originally Posted by ed taylor View Post
    Ed,
    I've already got both a 3-in-one silicone lubricant and a 3-in-one white lithium grease spray (WD40 products) but neither say they are safe for use on plastic (just about everything else between them though ). I don't want to take a risk in case they damage the plastic as I don't even want to think how much that would cost to replace.
    After hours of searching, I've now found SG85 which definitely says it's OK to use on plastic (apparently it's not based on petroleum distillates which is probably the reason why it is OK as this is what can damage non-oil resistant plastics) and I'm going to pick some up later today.
    http://www.gt85.co.uk/products.htm
    http://www.machinemart.co.uk/shop/pr...ase-200ml-sg85
    Any thoughts on this?
    Mar 2007
    Tamworth
    Silicone is the "universal" lubricant - it's only downside is that final traces of it can never be removed so don't use it on components that need painting later - ie degreasing doesn't work on silicone.
    Wales
    Silicone grease - you can get it in Maplins (£3?). Great for rubber brake parts too!
    Oct 2007
    Shropshire
    Mine was done with vasaline to stop it rattling!!!
    Nottinghamshire
    Thanks for the advice, everyone.
  1. Corsa-C Gear Linkage
    By LJ sxi-nav in forum The 'Off Topic' room
    Last Post: 8th June 2010, 14:39
  2. Gear linkage knackerd
    By stitchi1973 in forum Suspension, Wheels & Brakes
    Last Post: 29th October 2009, 14:32
  3. Manual Gear Linkage ?
    By 900ss in forum Engine & Drivetrain
    Last Post: 24th June 2008, 14:14
  4. Gear linkage cables
    By prm in forum Vectra C / Signum Car Chat
    Last Post: 7th December 2006, 15:19
