Thread: Bit of an odd one
    Regular Member P-Mutton2.2's Avatar
    Aug 2009
    Frinton on sea
    Default Bit of an odd one
    Hi all,
    Got a wierd noise, sort of a creaking/mabe a rattle but not really... like something's straining under load when pulling away or getting moving at slow speeds,.. really no idea what it could be, sounds horrible have been aware of it for a week or so when driving, then heard it from outside when seeing wife off this morning could it be?
    hope some one has an idea cos sounds a bit worrying
    (sorry for oblique description but is hard to describe)
    thanks in advance
    Blantyre
    Is it just in the morning after the car has been sitting in the cold all night ?
    Or is it all the time
    Aug 2009
    Frinton on sea
    "Is it just in the morning after the car has been sitting in the cold all night ?
    Or is it all the time?"
    Guess it could be mainly in the morning but i'm sure i've had it at other times in the day? just such a strange shuddering type noise but don't really feel it if that makes sense, just don't want summink to fall off
    Mileage : 000
    Could it be the radiator mounting bush,s. They are known to creak. So are the Anti roll bar bush,s.
    Aug 2009
    Frinton on sea
    how bad would they sound? seems like a bigger noise than those, won't (i hope) be bushes as just recently done.
    thought it could be something loose under car, but no rattle or tinny clatter from exhaust etc..
    Regular Member andymagee1982's Avatar
    May 2008
    Widnes.
    Is the hand brake sticking?
    Aug 2009
    Frinton on sea
    that's a thought,.. feels like that kinda thing but only recently re adjusted the h/brake and new calipers... just a kinda groan on pulling away,
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    Could be the old faithful spring problem, as the car pulls away the weight is shifted - stretching the front ones and compressing the rear. also does it do it during braking??
    Gazza4
    Aug 2009
    Frinton on sea
    doesn't feel like suspension, again have only recently fitted eibach/bilstein set up plus all bushes, so would be suprised. Haven't noticed it when breaking but will listen out for it
    Jul 2009
    sussex
    engine mounts might be worth a check.
