Thread: bypass ABS sensors
    West Midlands
    Default bypass ABS sensors
    Hi
    I use brake pads with no wear sensor built in so how can I bypass the ABS sensors to stop the fault light coming on on my dashboard?
    WGAF#5
    are you sure you have an abs fault - have you knocked a sensor when fitting pads??
    the brake pad warning symbol is actually a round circle with lines either side of them
    like this one
    http://www.vectra-c.com/forum/showth...wear+indicator
    - this can be bypassed by wiring the connectors together to close the circuit - BUT if you have any other warning lights then you have a problem with the braking circuit and need to resolve it as a matter of urgency otherwise your abs wont work in the event of an emergency stop
    leeds
    why would you want to bypass the abs lamp on warning? if its for mot reasons then it will still fail for not illuminating. if not then just stick some tape over it allthough i'm the same as detz for saftey reasons it needs rectifying
    11 Post(s)
    Is it me, or is the OP confusing the ABS sensor for the brake wear sensor? Sounds to me that he just wants to bypass the brake pad wear sensor to stop the brake pad warning light from coming on.
    West Midlands
    sorry guys. I meant to say brake wear sensor. As I use pads with no wear sensor my light is always on. How do I bypass the brake wear sensors is what I should have asked
    West
    Bodge it & scarper lmao...
    Nottinghamshire
    Do you mean that the pads don't have the recess for the sensor to fit into? They should do if they're the right pads for the car.
    The sensor is about £10 from a dealer - there's a few so check you get the right one for your car and make sure the cable is properly routed and secured when you fit it.
  1. bypass limpmode???
    By dazza2393 in forum Engine & Drivetrain
    Last Post: 24th September 2012, 20:13
  2. egr bypass thought
    By james walker in forum Vectra C / Signum Car Chat
    Last Post: 15th March 2012, 12:17
  3. Red SRI Farnham bypass
    By bigboynigs in forum Spotted or put a flyer on a Vectra C/Signum or Insignia?
    Last Post: 22nd May 2010, 13:46
  4. Handbrake bypass
    By Dippy-Vx-line Red in forum Electrical & ICE (including SatNav)
    Last Post: 30th October 2008, 12:12
how to bypass abs sensor
vectra c brake pads light bypass
vectra c bypassing speed sensor
vectra c speed sensor bypass
Vauxhall Vectra abs bypass
vectra c abs sensor
hiw to bypass low break warning sensor on vectra c
vauxhall vectra bypass abs light
how to bypass a abs sensor peugeot 206
abs sensor bypass
vauxhall brake sensor bypass
how to fit vectra c abs sensor
vectra wheel speed sensor bypass
