Thread: Car Battery
    Default Car Battery
    Hi guys,
    Ive bought a Bosch-Battery S6 from ebay, i didnt check the measurements later realising that it may actually be too big for the tray!!
    the measurements are in mm, 353 length, 175 width and 190 height....
    please could someone confirm if this will fit ??? fingers crossed....
    being fitted in a vectra c 2.0 dti 04..
    well im going to pick it up now anyway... measured the tray and it seems it will be tight but should be able to fit it in..
    Oct 2009
    Bilbao&Madrid
    Vehicle : Opel Signum
    Trim : Cosmo
    Engine : 3.0 CDTI Z30DT
    Quote Originally Posted by siz1 View Post
    Not of much help if you squeeze it but there it goes, anyway: the two batteries in the Bosch catalog for your model are 315x175x175 mm in size.
    S4
    Trade Numbers: 12V 80AH 740A, 580 406 074
    To MY: 09/2005
    Voltage: 12 V,
    Battery Capacity: 80 Ah
    S5
    Trade Numbers: 12V 85Ah 800A, 585 200 080
    To MY: 09/2005
    Voltage: 12 V,
    Battery Capacity: 85 Ah
    Oct 2009
    Bilbao&Madrid
    Trim : Cosmo
    And it would be waaaay better if I had provided the link to the catalog, in case I selected the wrong model:
    http://ecat-online.bosch.de/toc/
    Select language, maker, model, year, engine capacity...
    You should allow pop-ups at some point in the process.
  1. battery wiring block next to battery 150tdci - HELP
    By jameslunt in forum Electrical & ICE (including SatNav)
    Last Post: 2nd July 2012, 07:19
  2. Key fob battery
    By Fausty in forum Electrical & ICE (including SatNav)
    Last Post: 23rd December 2011, 02:38
  3. Battery
    By Wolfie01 in forum Electrical & ICE (including SatNav)
    Last Post: 7th December 2011, 23:52
  4. Battery Light ON - 14.1 volts at battery
    By snapsnap in forum Electrical & ICE (including SatNav)
    Last Post: 6th December 2011, 13:55
  5. Battery light on, 14.4V at the battery!
    By Saulty in forum Electrical & ICE (including SatNav)
    Last Post: 16th January 2011, 23:29
vectra 2.0 dti battery 315
