Thread: Rear Wiper not working. help
    Cornwall
    Default Rear Wiper not working. help
    Having just discovered this forum can I ask you experts for some help?
    Some time ago my rear windscreen wiper packed up. It started by going a bit juddery when in use then just packed in altogether.
    I assume its the motor, the click sound is still there when I try to turn it on using the steering wheel paddle stick but nothing happens.
    Is it an easy job to replace? Would anyone have a part number? I've got a Vectra 52 plate. Is it easy to get the trim off to gain access? Is the motor under the trim near the wiper base or somewhere else?
    Sorry about all the questions, i've searched the forum and can't find the answers.
    HELP!!!!!!!!!!!!!!!!!!!!
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    Is it the Stock that sticks or the Wiper itself??
    If it is the wiper motor, to replace the boot lid interior trim will need to be removed - its held on with e few torx screws.
    I dont know how much a new motor is though.
    Gazza4
    Cornwall
    I think its the stock that sticks.
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Mileage : 40000
    Quote Originally Posted by Ayrcomm View Post
    Think it is about £15 but not entirely sure.
    Does it click on and off ok?
    Gazza4
    Cornwall
    sorry, i was mistaken, its the wiper itself that is not working, the stock is fine, it clicks on and off.
    any ideas?
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Mileage : 40000
    Motor m8
    Cornwall
    cheers, any idea of how much or part number & is it an easy job to do?
    Regular Member spatch's Avatar
    Aug 2007
    Kent
    I just seen this post. I had exactly the same problem and it turned out to be dirty contacts in the motor itself. You have to remove the motor from the car and once apart you will see that the operation of the motor is controlled by contacts on a disc. On mine, these were dirty. After a clean up and regrease it was all fine again.
    Worth a try before buying a new one, and not too difficult to do.
    Hope this helps.
    Cornwall
    thanks spatch, i'll give it a try before I fork out for a new one.
    East Scotland Regional Organiser signumboy's Avatar
    Edinburgh/outskirts
    Engine : 2.0 Ltr Turbo
    Mileage : 38000
    Had this problem with mine too ...there was nothing wrong with motor its the arm that comes through the body or window in my case all you need is to lubricate it and it should work fine
  1. rear wiper not working?
    By crinks85 in forum Bodywork & Interior
    Last Post: 5th March 2012, 21:18
  2. Rear wiper not working
    By Vectra- in forum Electrical & ICE (including SatNav)
    Last Post: 15th September 2011, 20:13
  3. Rear wiper stopped working!!
    By marwen in forum Electrical & ICE (including SatNav)
    Last Post: 10th September 2009, 21:29
  4. wiper not working???
    By thompo5 in forum Vectra C / Signum Car Chat
    Last Post: 30th November 2008, 18:10
  5. Rear Wiper Not Working
    By djr69uk in forum Electrical & ICE (including SatNav)
    Last Post: 21st August 2008, 15:57
insignia rear washer and wipers not working
insignia rear wiper not working
vectra rear wiper not working
vectra c rear wiper not working
