Thread: ARB sizes.....Again!!
    Regular Member JamesGTB's Avatar
    Jul 2009
    Default ARB sizes.....Again!!
    Evening all,
    I know there has been several threads on here about ARB sizes but has anyone come to find the right size?
    I am going to need to change mine soon but cant find the exact sizes for the front and rear unless i take them off first but would ideally like to change them there and then.
    I have a friend that works in a Saab garage in the parts department which i have service items from and i believe the drop links and ARB`s are the same as the 93 but need part numbers from the vauxhall equivalent to match them up but he cant without the sizes.
    Can anybody help or has anyone changed them on the Vectra CDTi Estate ??
    Thanks in advance.
    Regular Member danBoy's Avatar
    Jun 2006
    Northampton
    There are 3 sizes on the front 24mm, 24.2mm and 25.2mm.
    On the rear there are also 3 different sizes 17mm, 18mm and 19mm.
    Regular Member Jezzy's Avatar
    S.E
    PM me your reg number mate and hopefully only one size for each end of the car will be listed, so we'll know which size you need. BTW, I assume it's the ARB bush you want to change, not the ARB itself?
    Jul 2009
    Thumbs up
    Quote Originally Posted by danBoy View Post
    Apparently the 19mm rear and the 25.2mm front is for a sport chassis or larger capacity engine such as the V6 etc; so really i could fit either of the two remaining sizes as there is only up to 1mm difference,the smallest is probably the best bet.
    **Quote Jezzy**
    Very kind of you,yes its the bushes i need to change,i have tried Vauxhall and they have told me the same as above with the different sizes as well as my mate in parts,maybe you will be able to see the correct ones??
    PM on the way
    S.E
    Right, PM with reg number received. For the front, it's showing two sizes, 24mm and 25.2mm; it's not showing the middle size. If I had to wager which it was, I'd go for the smaller one. However, as they only cost about £2.50 each, I think you should buy 2 of the small ones and 2 of the large ones, and when you take the old ones off you can compare the part numbers with the new ones. Plus, there's a good chance you'd get a refund on the unused pair.
    For the rear, better news - it lists 18mm and 19mm, but mentions that the 19mm is for the "lowered sports chassis", i.e. SRi spec, so 18mm is the one to go for (part number 24457386).
    Jul 2009
    Thanks for all your help mate,i will report back when i get them fitted so others wont have to search far for the answer.
    Hopefully it will be soon but there is something called Christmas that takes up one weekend,how inconsiderate
  1. tyre sizes
    By chris1804 in forum Handling & Braking
    Last Post: 19th January 2013, 13:22
  2. Tyre sizes
    By Biff600 in forum Suspension, Wheels & Brakes
    Last Post: 30th March 2010, 20:33
  3. tyre sizes
    By pmitchell in forum Vectra C / Signum Car Chat
    Last Post: 8th February 2010, 19:05
  4. Spring Sizes
    By rob1964bike in forum Suspension, Wheels & Brakes
    Last Post: 26th January 2010, 12:57
  5. 3.2 pad sizes.
    By jamesr in forum Handling & Braking
    Last Post: 14th July 2008, 10:47
