Thread: Checking oil
    luton
    Default Checking oil
    Hi
    Stupid question guys, i have a 1.9td sri, only had it a couple of months, checked the oil, i thought the level shoud come to the top of the flat bit on the dip stick, but i'm doubting myself now, could some confirm this for me, cheers
    Its in tha manual iirc
    Also you check the level after the engine has been running, I believe there should be a sticker on the slam panel indicating how to do it correctly.
    Regular Member Grimo72's Avatar
    Apr 2008
    Lincs
    if you check it when cold, you will pass out as it indicates that there is too much in...............
    run the car till at normal running temp. switch off, leave 5 mins then check.............................
    cheers
    Wales, UK
    Quote Originally Posted by Grimo72 View Post
    cheers
    Thanks mate, you saved me from passing out as I have just looked and thought, OMG !!!
    I find there is very little difference between checking oil on cold or warm
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    Anytime I check the oil the oil is always up the dipstick. And before any1 says its over oiled - it does not put out any blue smoke and I can switch the engine off no bother.
    The dipstick is completely uselss imo.
    Gazza4
    Apr 2008
    Lincs
    Quote Originally Posted by Gazza4 View Post
    Gazza4
    very true. not very accurate ..........
    Regular Member 67688c's Avatar
    Apr 2008
    In UK
    There probably is a slight difference as oil expands when warmer.
    The reason I mention this is because on my BMW E90 3 series the petrol versions do not have a physical dipstick at all.
    It has a electronic sensor using some form of thermal strip device in the sump, it then gives a oil reading on the computer display, ie. showing the minimum marks and also a max position, and is easily to see if it's over filled.
    I notice on mine at the moment that for the first few miles until it's warmed up it will show one segment below the max mark on the graphic display, but once its fully warmed up, it then shows on the maximum mark, so I am assuming that oil must expand slightly when warm.
    Though obviously the angle of the car should idealy be fairly level, it does'nt seem to make a lot of difference to the readout on the BM, not that I've noticed anyway. Possibly due to the engine being further back perhaps.
  1. just checking
    By tosh23 in forum Introduce yourself.
    Last Post: 24th October 2012, 18:15
  2. Checking in
    By Craigk in forum Introduce yourself.
    Last Post: 15th October 2009, 18:13
  3. VX checking a car
    By T4M in forum Vectra C / Signum Car Chat
    Last Post: 5th October 2008, 21:22
  4. Checking MOT
    By Ste in forum Vectra C / Signum Car Chat
    Last Post: 9th April 2008, 22:55
  5. Just checking
    By Canyonroll in forum Signature & Avatar Testing
    Last Post: 6th May 2006, 12:48
