Thread: HIDS - Department of Transport factsheet.
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    Engine : 140 Ecoflex S/S
    Default HIDS - Department of Transport factsheet.
    Not sure if this has been posted before but just lifted this from another forum and item #2 makes for interesting reading:
    Fact sheet: Aftermarket HID headlamps
    December 2006
    In the Department's view it is not legal to sell or use after market HID lighting kits, for converting conventional Halogen headlamps to HID Xenon. If a customer wants to convert his vehicle to Xenon HID he must purchase completely new Xenon HID headlamps. The reason for this is that the existing lens and reflector are designed around a Halogen filament bulb, working to very precise tolerances. If one places a HID "burner" (bulb) in the headlamp, the beam pattern will not be correct, there will be glare in some places and not enough light in other places within the beam pattern.
    The following is the legal rationale:
    The Road Vehicle Lighting Regulations 1989 regulate the situation in the UK.
    Under these Regulations, HID/Gas Discharge/Xenon headlamps are not mentioned and therefore they are not permitted according to the strict letter of the law.
    However new vehicles have HID headlamps. This is because they comply to European type approval Regulations. The UK cannot refuse to register a vehicle with a European type approval. These are to ECE Regulation 98 (for the HID headlamps which are tested on a rig in a laboratory) and ECE Regulation 48 (Lighting Installation on the vehicle).
    For the after market, a used vehicle cannot obtain type approval because it is only applicable for new vehicles. However we feel that saying "HID is banned in the after market" would not be reasonable. Instead we should make analogies with new vehicles. It would be reasonable to require HID in the after market to meet the same safety standards as on new vehicles. The same level of safety should apply.
    Therefore a HID headlamp unit sold in the after market should:
    1. be type approved to ECE Regulation 98 as a component.
    2. when fitted to the vehicle should enable ECE Regulation 48 to be complied with (although no government inspection will take place).
    3. Comply with RVLR as far as "use" is concerned.
    In practice this means:
    1. The headlamp unit (outer lens, reflector, bulb) shall be type approved to ECE 98 and be "e-marked" to demonstrate this. That can only be done by the headlamp supplier - Hella, Valeo etc. who must test the headlamp in an independent laboratory.
    2. Once fitted to the vehicle it must have headlamp cleaning and self-levelling (which can be for the headlamp or can be in the vehicle suspension - some expensive estate cars have "self-levelling suspension" and that is adequate). Also the dipped beam must stay on with the main beam.
    3. The headlamp must be maintained in good working order, kept clean, and aligned/adjusted correctly like any other headlamp.
    Under the Road Traffic Act 1988 it is an offence to supply, fit or use vehicle parts which are not legal.
    In summary it is not permitted to convert an existing halogen headlamp unit for use with HID bulbs. The entire headlamp unit must be replaced with one designed and approved for use with HID bulbs and it must be installed in accordance with the rules stated above.
    If you require any further information regarding the regulations covered by this fact sheet, please contact the DfT at the address below:
    Transport Technology and Standards 6
    Department for Transport
    Zone 2/04
    Great Minster House
    76 Marsham Street
    London
    SW1P 4DR
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    Thats the beauty of the Veccy as most of the healight units have the projector lens.
    Regulation 2 is abit of a pain though.
    Gazza4
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    On vecs or sigs are the headlight units the same for Halogen and HID as standard fit?
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Mileage : 40000
    Quote Originally Posted by Ste View Post
    No m8, if you have manaual levelling on the headlight switch module in the car then they are not HID compliant.
    If you have auto levelling, self levelling suspension, headlight washer system and the headlight unit build for HID bulbs then thats where you can legally fit them.
    Gazza4
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Maybe I should have been clearer in my post.
    I was refering to the headlight unit only. I know that these additional things are required - washers, self levelling. But are the actual head light units the same? Or if not, what are the actual differences.
    Full Member Big Sig's Avatar
    The lense unit is basically the same ste.
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Mileage : 40000
    think the Xenon ones have ballast fitted and hence slightly bulkier at the back but not 100%.
    http://cgi.ebay.co.uk/Vauxhall-Vectr...item3efa814dfd
  1. A trip to the A&E Department
    By tanya_baby in forum Comedy & Humour
    Last Post: 30th November 2011, 22:01
  2. department of enviroment
    By Deztroyer in forum Comedy & Humour
    Last Post: 19th May 2009, 08:47
  3. Government Department
    By Baldy in forum The 'Off Topic' room
    Last Post: 25th April 2008, 01:33
  4. Department of Transport Warning
    By AJA in forum Comedy & Humour
    Last Post: 25th May 2006, 18:01
  5. Reg Vardy Parts Department
    By Telboy in forum General Chat
    Last Post: 14th May 2006, 20:33
