Thread: What are the chances ?
    Regular Member JamesGTB's Avatar
    Jul 2009
    Default What are the chances ?
    Hi All,
    I have had my 55 plate Vectra Estate 1.9 CDTi for just under a year now which i bought from a dealer with one year NetworkQ warranty with 42,000 miles on the clock.
    I thought id do a bit of an info hunt about the cars warranty history from before i took ownership and contacted the garage from where it was registered to find that it has already had the DPF,Inlet Manifold, EGR Valve,and the Air-Con Compressor replaced under the manufacturers warranty which i thought was absolutly fantastic,but what are the chances of the major items failing again such as the DPF and the Inlet ? has anyone had to have theirs replaced more than once ??
    James
    The world famous city ground
    Vehicle : Vectra cdti estate
    Trim : Get a
    Engine : Dirty diesel
    i have had the dmf and clutch replaced twice, first time due to oil misting from a leak on the bottom end, then due to a vibration (even though i had a noise from the alternator)
    hth
    Midlands Mod Shop - NFFC.
    asdasd
    Happens alot..Heard loads of peoples failing
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    tbh the DPF is how you drive it - needs to be driven hard from time to time.
    DMF are just owners luck and inlet manifold like the DPF - occasional hard driving should help keep them clean.
    Gazza4
    Leicester
    Never had an EGR/Inlet or DPF fail on me in 4 CDTi 150's and nearly 200,000 miles. My current car has had a new DMF though due to the way it was driven before I had it.
  1. What do you think are the chances?
    By signum_rob in forum Vectra C / Signum Car Chat
    Last Post: 29th November 2011, 17:59
  2. What would the chances be of....
    By John LE in forum General Chat
    Last Post: 15th June 2010, 21:37
  3. What are the chances....
    By danBoy in forum General Chat
    Last Post: 19th December 2009, 16:19
  4. Whats the chances of ?????
    By Pepsi Max in forum Vectra C / Signum Car Chat
    Last Post: 9th February 2009, 21:56
  5. What do ya rekon the chances are
    By markja in forum General Chat
    Last Post: 14th April 2008, 19:08
