Thread: 1.9 150 vectra SRI - new owner questions
    Regular Member ggg1979's Avatar
    Kettering
    Default 1.9 150 vectra SRI - new owner questions
    Hi, just purchased a 2007 (57) vectra 1.9 150 SRI from a garage with 44k on the clock. I have been looking through this forum to see if there are any known issues that could or have happend with this model, and there seems to be quite a few! EGR valve, Swirl valve, DPF, Fuel pump, inlet manifold...etc etc!
    Just wanted to ask what would be the best way to find out if the car has previously had any of these problems or what are the signs if they are happening? Its still got a years VX warrenty left thank god!
    Gary
    Lancashire
    Vehicle : Vectra SRi
    Trim : XP1
    Engine : 1.9 CDTi 150
    Mileage : 66000
    There are loads of threads on this mate, the search function at the top will be your best friend
    But, the highlights are as follows:
    • DMF - mettalic rattle when clutch is half pressed to start with, but after a while it will do it all the time the clutch isn't pressed (about £1000 with new clutch and master/slave cylinders).
    • EGR - Lack of power below 2K revs, the car should pull from 1500rpm, but an EGR fault would cause this to happed after 2K instead (free to clean, about £100 to replace).
    • Boost Sensor - As above (free to clean, about £50 to replace).
    • 3rd Injector Wiring - As above, but pre 2007/8 cars (£13 wiring fix from VX).
    • Inlet Manifold / Swirls - As above, but costs alot more to fix (about £750).
    These are specific CDTi 150 issues, the usual "Vectra" ones are ontop of this...
    • Wiper Linkage
    • Snapped Coil Springs
    • Rattling Boot lids etc.....
    Have fun
    Oct 2009
    Teesside
    VOTING UKIP IN AVELEY
    Vehicle : Vauxhall
    Trim : Astra Twin Top
    Engine : 1.9cdti
    Year : 07
    Hi Gary ,just VX a ring they should have a list of all the work done on your car .
    Kettering
    cheers lads thanks for your help
  1. 2 questions (for now, new dti owner)
    By mick.n in forum Vectra C / Signum Car Chat
    Last Post: 16th December 2010, 17:43
  2. Signum questions for new owner
    By jeffire in forum Vectra C / Signum Car Chat
    Last Post: 6th May 2010, 07:42
  3. new vectra c sri owner-questions!!!!
    By boardinbob78 in forum Vectra C / Signum Car Chat
    Last Post: 10th October 2009, 15:10
  4. Questions about 1.9CDTi (150) from new owner of a Vec
    By Geo77 in forum Engine & Drivetrain
    Last Post: 1st October 2009, 20:31
  5. A few questions from a new Signum owner...
    By marly in forum Vectra C / Signum Car Chat
    Last Post: 18th April 2007, 21:16
