Page 1 of 4 123 ... LastLast
Results 1 to 10 of 36
Thread: CAN bus radio into a non can bus car
    manc
    Default CAN bus radio into a non can bus car
    Hi,
    is it possible to fit a cd player from a can bus car into a non can bus car?
    Or is it possible but with wire modifications?
    I ask because i have a cd player from a 2006 vectra and i want to know if i can fit it into my 2004 corsa c.
    cheers lads
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    I'm sure it could be done mate, but we dont even put the Full Can HU's in the Early Half Can cars.
    Nov 2009
    Norfolk
    Quote Originally Posted by lennard2009 View Post
    Hi,
    cheers lads
    I got a can bus stereo for my half can bus Signum.
    Stereo connections are wrong for a start (main plug etc)
    Plus the can bus stereo forms part of the immobiliser and alarm system on the can bus car.
    Probably possible but is it really worth the hassle?
    Mar 2007
    North East
    Hi,
    cheers lads
    One of the guys on here has fitted a CD70 into a cavalier, so quite possible. Have a search for posts from Robsey.
    Full Member Robsey's Avatar
    North East Cheshire
    23 Post(s)
    Trim : Energy
    Mileage : 131,000
    Yes it is possible to do, if you are quite adventurous...or in my case mad.
    As said above, I fitted a full can CD70 Navi and Graphic Info screen to my non-can cavalier mk3.
    You will need an ISO2CAR loom, or SOT lead with the quadlock and ISO plugs on it.
    You will need the screen plug also.
    To get my lights and temperature read-out working, I also had to get a scrap light switch unit and a body control module. The unit is standalone from the majority of the cavalier's systems, therefore I don't have a board computer function.
    Bear with me a second, and I will find my full thread on the Mk3 Cavalier Owners Forum, which discusses this in great detail.
    North East Cheshire
    23 Post(s)
    Trim : Energy
    Mileage : 131,000
    Here is the thread on the other forum!!
    http://www.cavmk3oc.com/forum/viewtopic.php?f=15&t=2871
    Hampshire
    hi
    just want ask a stupid question
    I got a 54 signum comes with ncdc 2013
    any chance I can replace 2013 with CD70?
    North East Cheshire
    23 Post(s)
    Trim : Energy
    Mileage : 131,000
    Yes can be done...you will still need the ISO2CAR or SOT lead, but not all the light switch and BCM bits, as your car will have these.
    You will need different wheel controls and possibly need to change / reprogram your CIM module.
    The BCM from a half can car works fine with the CD70...that's what mine is.
    Another query relates to the airbag circuit...it is believed that there are some possible issues with a half can airbag system and a full can CD70. (Bigmac advises that this issue has been discussed on the german equivalent of this site).
    If in any doubt, I would suggest leaving the low speed can wire on pin 25 of the display disconnected. This wire links the airbag circuit to the display check control circuit.
    Facia wise, it is just plug and play...do watch out for facelift colour screens, as some are of the wide screen variety, and this will entail some fettling of a facelift surround to fit it to a pre-facelift dashboard.
    Hampshire
    waooo
    sounds like a huge job for me
    does anyone done this before?
    North East Cheshire
    23 Post(s)
    Trim : Energy
    Mileage : 131,000
    The majority of the work is just making up the conversion loom.
    Mechanically there are no issues.
    Electrically...the more functions you want, then the more complex it becomes!!
    Although if you are happy to stay away from wheel controls and airbag wiring, then it is not too bad at all to do.
    The tricky / fiddly bit is fitting the sat nav aerial...especially as space is tight to feed the block into the speaker hole in the top of the dash.
    Just follow any of my threads, either here or on Cav3 owners Club forum...there are bags of pictures and wiring diagrams available.
  1. CDC 40 radio
    By dave b in forum Electrical & ICE (including SatNav)
    Last Post: 23rd October 2012, 23:20
  2. Radio 1
    By vec-cal in forum Electrical & ICE (including SatNav)
    Last Post: 31st August 2010, 00:17
  3. my radio
    By the fisherman in forum Vectra C / Signum Car Chat
    Last Post: 18th May 2010, 21:29
  4. CD 30 Radio
    By Stevel in forum How much is it worth? (THIS SECTION IS NOW CLOSED)
    Last Post: 13th July 2008, 17:15
what vauxhall radios will fit a half can bus
can I fit up date car radio in vectra c
cdplayer with canbus on non canbus car
Will corsa c radio fit vectra c
canbus joying opel
opel corsa c canbus
joying for vectra c
does opel corsa 2004 has canbus
