Thread: Double din stereo fitting
    Jun 2007
    northants
    Default Double din stereo fitting
    I apologise if this has been covered before but i seem to be chasing my tail some what
    I have pioneer hd3 11 to fit to my 04 plate signum however after i have brought fascia surround and steering control lead i find that neither fascia fit or lead anything like the one fitted to my car - this kit has been sent back because apparently its for a later model (didnt realise there was different models)
    can anyone point me in the right direction for a fascia in dark grey (standard interior for 2.0t design) and a lead to connect to my push button controls on my steering wheel - the plug is the standard plug that has been used on cars for years plus a smaller one
    also has anyone have any ideas where i can put the bluetooth and ipod unit and gps receiver thingy? and also where to run the ipod lead into the car cabin
    thanks
    Full Member stuart bigboy's Avatar
    May 2007
    kent
    Default double din
    i got my facia from autoleads also the cables for the steering wheel controlls the gps antenna depending on weather you have the center speaker in the dash it can go there thats the best place
    Jun 2007
    northants
    thankyou does anyone have any ideas on best place to run the ipod connection from back of stereo into car - and also will my have a speed signal connection? the stereo has lead to connect not sure if my car has one
    Regular Member Robsey's Avatar
    North East Cheshire
    23 Post(s)
    Trim : Energy
    Mileage : 131,000
    Speed signal is the blue/red wire on pin 5 of the ISO plug of the main stereo lead. (cars upto October 2004).
    Be aware also which way you wire up permanent and ignition live wires...vauxhall has always done these the wrong way round..
    To help
    red is permanent live
    black is ignition live
    grey/black or grey/green is illumination
    red/white is aerial . amplifier supply
    brown is earth / chassis / ground
    The ipod connector can be placed anywhere you like, either a switch blank, or you can get a proper socket and cubby-hole box from Vauxhall. It will sit in the gap below you heater controls but above your ashtray.
    Jun 2007
    northants
    Another question for you guys - what colour fascia would i need to match my interior? autoleads list silver gunmetal grey, charcoal grey and dark grey as stated previously 2.0t signum design 2004 '04'plate also which of the leads would i need to get steering wheel buttons working with my pioneer hd3-11 and does this also work with the built in car screen? the stereo that came out originally was called something like cdr2006?!?!?!? (tape radio and cd muti changer head unit)
    North East Cheshire
    23 Post(s)
    Trim : Energy
    Mileage : 131,000
    I would expect it to be charcoal grey...
    If you take out the headunit, it will have a large sticker on it with the two lettercolour code on it...
    Charcoal is CC Otherwise look for the colour panel arrowed!!
    Jun 2007
    northants
    thankyou i will have to search out the original stereo (i changed it for a single din unit a couple of years ago) any body have any idea what steering wheel connecters i need and whether the screen will still work?
    North East Cheshire
    23 Post(s)
    Trim : Energy
    Mileage : 131,000
    make sure your wheel connectors will fit the ISO connectors...same as the Omega B. not the later quadlock
    Most SOT leads come with the quadlock...if needs-be contact the seller first.
    Note also Halfords are usually approx twice the price of everyone else.
    The wheel control wires will be "radio Manufacturer" specific JVC, Kenwood or Sony..etc
    Yes wth the correct adapter loom the display will indeed work, but it will not show info from your aftermarket radio....just clock, temperature, date and BC if GID or higher
    Jun 2007
    northants
    dont think its quad lock! stereo connects with standard plug like in a calibra with standard aerial connector if that helps
    does the black plastic cage thing thats set in the dash need removing?
    North East Cheshire
    23 Post(s)
    Trim : Energy
    Mileage : 131,000
    Aye that's what I said...
    Yours is the old ISO connection as used on Vauxhalls between 1987 and October 2004.
    The most reliable way to get a loom to suit is to ask for one for an Omega B (1998 to 2003).
    As also said...most leads identified as SOT units have the quadlock plug, hence why I said "check with seller" before you buy...just incase they assume that all Vectra C's have the same connection.
    also - double din is a european "cage size" standard, and apart from the holes at the back for connectors...they should be very similar.
  1. Double din stereo help !!!
    By Antsmart in forum Electrical & ICE (including SatNav)
    Last Post: 31st December 2012, 00:16
  2. good double din stereo?
    By nico243 in forum Electrical & ICE (including SatNav)
    Last Post: 18th June 2012, 10:57
  3. Which stereo to put in double or single
    By VECTRA1974* in forum Electrical & ICE (including SatNav)
    Last Post: 15th January 2011, 14:08
will a aftermarket 7inch stereo fit my vectra c
double din stereo in vectra c
