Thread: Plumbing Advice Needed..
    Regular Member Jezzy's Avatar
    S.E
    Default Plumbing Advice Needed..
    I'm looking to buy a set of bath and shower mixer taps, the ones I'm interested in say the minimum pressure required is 0.4 bar. Is this a fairly standard figure, or is it high for a minimum? My only reference point is that basin taps I fitted downstairs are rated to work with a minimum 0.1 bar.
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    Engine : 140 Ecoflex S/S
    Assumimh you've got a gravity fed system (cold water stoage tank in loft and hot water cylinder elsewhere), you'll have at least 0.4m between the taps and the base of the tank.
    0.4m is quite standard as with a bath/shower mixer, you'll need the 0.4m as stated by the manufacturer to hold the diverter knob open when you're using the taps in shower mode.
    HTH.
    S.E
    Thanks; yea it is indeed a gravity-fed system, was just worried that 0.4 might not be typical for one of these taps. Cheers for the advice.
    1 bar = 30ft head of water 15 psi approx if my brain is in gear hth ........
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    Quote Originally Posted by Tadpole View Post
    Thanks Tadpole for bringing me back to reality - jeez, what was I thinking .
    The OP stated 0.4 bar which is indeed 4 metres and I've misread this as 0.4 metres - sorry Jezzy .
    The bath/shower combo may not necessarily work then and, as it's a gravity system, you'll probably have no more than 2 to 3.0 metres from the taps to the base of the tank.
    Sorry for any confusion.
    Regular Member poves's Avatar
    lancashire
    I used to do a bit of plumbing with the father in law , and we always used to put a pump in to get the pressure up .
    S.E
    Quote Originally Posted by gtr1000 View Post
    I have got bath/shower mixer taps at the moment, which work fine, but as they're 5 years old I don't know what their minimum bar rating is, i.e. whether it's less than 0.4 bar
    S.E
    Just had a thought, is a gravity fed system (such as I have) also known as "low pressure system"? If so, I should be ok, as the taps are stated to work with a low pressure system.
    Must had the right head on after all Mr Gtr ....... hope you sort this out Mr Jezzy ......
  1. Replies: 28
    Last Post: 16th October 2012, 21:23
  2. Plumbing advice needed.
    By chrissri82 in forum General Chat
    Last Post: 6th December 2011, 13:56
  3. Emergency plumbing question
    By craigbarlow18 in forum The 'Off Topic' room
    Last Post: 4th January 2009, 20:58
  4. Small Plumbing Question
    By Damian in forum General Chat
    Last Post: 15th May 2008, 19:52
  5. plumbing advice
    By John35 in forum General Chat
    Last Post: 20th August 2007, 22:02
