Thread: CDC40 DAB safe
    Regular Member Neil71's Avatar
    Oct 2007
    Fraserburgh, Aberdeenshire
    Default CDC40 DAB safe
    Hi, I upgraded my CD30 to the 6 disc CDC40 with DAB radio some time ago. At the time of installation I didn't have the DAB aeriel or module. I have since then fitted these parts and followed the instructions I received with the parts. I took my car to my local VX dealer where the technician tried to Tech2 the module to work. The display showed DAB SAFE and the DAB radio signal would play for a few seconds, silent for a few seconds, this happened all the time.
    Any advice on this problem would be greatly appreciated.
    I don't know if the technician knew what he was doing.
    Full Member Robsey's Avatar
    North East Cheshire
    22 Post(s)
    Trim : Energy
    Mileage : 131,000
    Did the wording DAB flash on for a few seconds at a time, or did it stay displayed constantly.
    flashing dab means that it needs marrying to the radio and display.
    constantly displayed DAB SAFE means that the module has not been unpaired from the previous vehicles radio / display.
    if it is still paired to the previous vehicle, then you will need someone to over-write the Eeprom to return it to transport / unpaired state..
    Then it can be programmed into your radio / display.
    If it is flashing safe, then the technician has failed to program it in correctly...missed off some modules, or did not input the correct vehicle model code.
    Oct 2007
    Cheers, If I remember correctly it flashed DAB SAFE, it wasn't on constantly.
    If it needs overwritten on the eeprom how is this done, is it done via tech2?
    As I said earlier I don't think that the guy who was working the tech2 knew what he was doing.
    When I went along with the radio and screen to be installed he asked if the 6disc changer was going to be fitted under the seat or in the glovebox. He didn't know that the CDC40 has this built into it.
    Neil71
    Regular Member CristianTM's Avatar
    ROMANIA, Eastern Europe
    Send me eeprom content from CD40 Opera and from DAB. I will try to help you.
    CristianTM.
    Oct 2007
    How do I go about getting the eeprom information?
    Thanks Neil71
    You must find a local electronics workshop to read the internal eeprom. CDC40 must have 95640 or 24C64 smd eeprom and DAB I don't know, must search it inside !
    CristianTM.
    North East Cheshire
    22 Post(s)
    Trim : Energy
    Mileage : 131,000
    Returning to the fact that it only flashed SAFE and probably pinged or beeped, then this does NOT need the eeprom rewriting. Therefore you don't need to worry about this.
    It just needs a decent tech 2 operator...There are very few around who can do this properly, you may have to look around for an alternative vauxhall dealer or independent specialist.
    Jan 2014
    lincoln
    Vehicle : vectra c
    Trim : c
    Engine : 2.0
    Year : 53
    I have a 2005 vectra with built in dab the fm works fine but dab just says a solid safe yet it appears to be the original module would the fm work if it wasn't coded to the car i have opcom but on the dab option theres no programming option
  1. keeping your car keys safe! really safe
    By nicj in forum General Chat
    Last Post: 10th November 2012, 15:15
  2. CDC40 to CDC40 MP3 upgrade.... any advice?
    By eamond in forum Electrical & ICE (including SatNav)
    Last Post: 15th September 2012, 08:02
  3. CDC40 display safe prob
    By apollo996 in forum Electrical & ICE (including SatNav)
    Last Post: 30th September 2009, 09:15
  4. Is it okay to / safe to
    By Damian in forum Vectra C / Signum Car Chat
    Last Post: 16th November 2006, 11:15
https:www.vectra-c.comforumshowthread.php96810-CDC40-DAB-safe
dab safe
