Thread: headlight woes
    west yorkshire
    Exclamation headlight woes
    just fitted sri lights to my design 06, the problem is that the high beam is all ways on, on the passenger side, i changed the bulb but it still seems to stay on, all the other lights work ok on both sides,
    even the warning light on the info screen says "check main beam",
    any help please
    Mileage : 000
    Are all the conections clean. Might be worth giveng them a clean, just to make sure.
    Full Member Big Sig's Avatar
    Have you connected them up correctly?
    west yorkshire
    yes to both. all cleaned and in the right way.. seems strange that it stays on all the time( goes of when in side light mode,)
    WGAF#5
    the network is putting on the bulb as it believes the other bulb is out and not working to try and give you a "matched pair" so to speak - try swapping the bulbs from the working side and see if the fault transfers to the other side - at least this will rule out the bulb and then you can either look at the connector or wiring
    west yorkshire
    balls, didnt want to get my fat fingers stuck changing the drivers side again, cheers tho, give it ago in morning and take it from there,
    WGAF#5
    i appreciate its not what you wanted to hear - but if you can rule out the bulbs and wiring then it has to be a faulty lamp
    west yorkshire
    how could it be a faulty lamp.. the bulb only sits in the holder,,
    WGAF#5
    sorry Tony getting tired and distracted - i meant sensor
    west yorkshire
    no worries, thanks for the help
  1. More AC Woes...
    By Munkey in forum Vectra C / Signum Car Chat
    Last Post: 1st August 2012, 17:59
  2. new car woes
    By dunkf in forum Engine & Drivetrain
    Last Post: 11th July 2011, 11:55
  3. Mot woes!!
    By the-wizard in forum Vectra C / Signum Car Chat
    Last Post: 26th July 2010, 10:14
  4. headlight woes part 2
    By tony stoney in forum Electrical & ICE (including SatNav)
    Last Post: 6th December 2009, 19:44
  5. More Woes
    By VauxVeteran in forum General Chat
    Last Post: 15th April 2008, 23:52
