Thread: spanner and car orange light on 3.0 v6 cdti
    Sep 2009
    OMAGH
    confused spanner and car orange light on 3.0 v6 cdti
    this light has started coming up in my car betwen the rev and mph clocks some times it goes away but other times it just stays on. the car seems to be running fine and i dont know whats wrong. any ides guys... and also on another note a knocking noise going over bumps in the road this also comes and goes to, would this be the a broken spring that i have hread about on other fourms?
    thanks
    Full Member Robsey's Avatar
    North East Cheshire
    14 Post(s)
    Trim : Energy
    Mileage : 131,000
    knocking from the front does hint at a broken spring.
    knocking from the rear could be one of the suspension linkages.
    spanner light suggests that a fault has been logged!! or is present.
    there are a few faults common on the v6 cdti, which are well documented on the site.
    a fellow sufferer will be along soon to advise.
    EVERYWHERE
    You need to get the codes read. This will then give you some idea of what the problem is. It's probably a sensor that's playing up, but there are may other faults that are common to the v6 diesel.
    Full Member Big Sig's Avatar
    the knicking could also be a bush worn, rad mounts, anti roll bar drop links....... you need to have a look and not guess.
    Sep 2009
    OMAGH
    thanks very much guys, just wasn't sure in driving her over the weekned or not cause over the weekend she usally never cools lol.
    Quote Originally Posted by williamM View Post
    See your handbook; pages 30, 55, and 166
    This is most likely to be a fault in the fuel system
    Is the car under warranty?
    Do you notice any loss of power, juddering, or hesitation?
    I had this and it was found to be the bumper undertray knocking against the bumper
    The clips were replaced, but it made no difference
    Sep 2009
    OMAGH
    no sadly its out of warranty, must look at that undertray cause i has the bumpers just painted so that mite be it the undertray. what did you do then went the new clips didnt work on the under tray?
    Remove the undertray! Its only there as they are so damn noisy.
    Regular Member Celes's Avatar
    Slovenia, Koper
    Vehicle : Opel Signum
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    Removing the undertray also helps with cooling the engine oil which the 3.0 CDTi desperately needs if driven hard
    Regular Member Eirik's Avatar
    Aug 2009
    NORWAY/Kristiansand
    Quote Originally Posted by Celes View Post
    So it dosen't make turbulence/ ruin the airodynamics under the car if you remove it?
  1. V6 CDTI EML Spanner light
    By mattsbmw in forum Engine & Drivetrain
    Last Post: 15th August 2011, 21:38
  2. CDTI Spanner light after cold starts
    By Teapot in forum Engine & Drivetrain
    Last Post: 30th December 2010, 00:02
  3. cdti 120, spanner light.
    By frasedeb in forum Diesel Engine related
    Last Post: 11th June 2010, 06:50
  4. 1.9 CDTi (150) with spanner light...
    By parsco in forum Engine & Drivetrain
    Last Post: 23rd March 2010, 16:09
  5. 1.9 CDTI (150) Spanner light
    By djr69uk in forum Engine & Drivetrain
    Last Post: 17th September 2008, 15:44
spanner light on vax hall vectra v6 cdti
