Thread: Power Steering Question (Vectra 2.0 Active DTI)
    Cheadle
    Default Power Steering Question (Vectra 2.0 Active DTI)
    My power steering has been lost. No warning lights or anything. I am presuming loss of fluid to be the likeliest cause but I am not sure how I can check the fluid level or where to refill the fluid.
    Can anyone help please or suggest other possible likely causes?
    Thanks in advance.
    Regular Member glynn's Avatar
    stevenage, hertfordshire
    you pump is electronic, and is more than likely to be behind the front bumper under the drivers head light, they are none to pack up, but well worth checking first, but if the fluid is low you will need green power fluid, known as CHF, central hydraulic fluid,
    Cheadle
    confused
    Thanks for this. So I have to take bumper of to add more fluid?
    Quote Originally Posted by Shadrack View Post
    YES, you have 2 torx 20 screws in each front wheel arch, 5 plastic pins you need to pull out, and there is 2 plastic doles on top of the bumper, 1 each side by the head light, push the centre 1 down, but put your hand underneith so you dont loose it, then you just give the bumper a hard pull fron the sides first to realise it from the wings
    Cheadle
    tHanks for your help
    Kent
    I have the 2002 2.0 dti and the power steering resevoir can be accessed by taking the plastic liner out the drivers side wheel arch.
  1. Replies: 17
    Last Post: 11th March 2015, 00:55
  2. Power steering question
    By Chip in forum Vectra C / Signum Car Chat
    Last Post: 12th February 2013, 12:07
  3. Quick power steering question
    By MattW74 in forum Vectra C / Signum Car Chat
    Last Post: 27th September 2010, 09:53
  4. Rear power for small active sub?
    By _ZS_ in forum Electrical & ICE (including SatNav)
    Last Post: 30th November 2008, 00:37
  5. Power Steering Question
    By knoxy in forum Vectra C / Signum Car Chat
    Last Post: 13th August 2007, 11:09
