Thread: towbar wiring!!
    Regular Member kojak01's Avatar
    Feb 2007
    edinburgh
    confused towbar wiring!!
    hi. looking for some advise. i have a 2004 vec c sri estate. i have got my hands on a second hand towbar which is now fitted but the wiring kit that came with it is incorrect. can anyone tell me the if they know or have a place that sells cheap vehicle specific looms for this car. in urgent need but dont really want to fork out twice what i paid for the bar on the wiring!! any suggestions much appreciated. ebay coming in at about 60 quid, the cheapest so far.
    ohh one other thing i take it the two multi plugs under the boot floor (in the small compartment) are for the loom to plug into?
    thanks
    Regular Member 30ltr nutter's Avatar
    dunstable
    vx do sell a tow bar loom kit i think its about 40.00 it plugs in to the control unit in the boot but i had to have the power feeds ect switched on by vx as it is not programmed to work from factory so if u buy the vx loom then u have the tech 2 cost on top i hope this helps
    Feb 2007
    edinburgh
    nice mate. thanks for that. i do remember reading on here about the vx kit but couldnt find it. i know a couple of guys in the local vx workshop so ill give them a shout and get them to switch on power to loom once i got fitted.
    thanks again
    Mar 2007
    Tamworth
    Towsure also sell vehicle specific looms - check your car's model year (10th digit of VIN) as that's more important than registration year.
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Or you could just wire up without the kit. Takes a bit more time, but costs practically nothing. Just a couple of relays and a little time.
    Info here
    http://www.vectra-c.com/forum/showth...ghlight=towbar
    Mar 2007
    Tamworth
    Quote Originally Posted by Ste View Post
    Info here
    On any modern car, it's best to use a 6 or 7-way relay - that way any check control systems aren't confused. The relay will need a 20 amp supply which is available using the red cable to the connector socket behind the trim somewhere - a 20A fuse is normally needed to be fitted in the fuseboard.
    Jan 2008
    Lincs
    Vehicle : Vectra C Hatch
    Trim : Exclusive Plus Pack
    Engine : 1.9 CDTi Z19DTH
    Year : 57
    Mileage : 100k+
    You may not need tech2 - I got the Vx kit and it just worked.
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Quote Originally Posted by Ruperts Trooper View Post
    I was just posting up an alternative method that is ultra low cost and works without upsetting any checks and balances. Up to the user to how they achieve the end result though.
  1. Towbar wiring need some help please
    By jel0611 in forum Electrical & ICE (including SatNav)
    Last Post: 4th April 2012, 11:37
  2. Towbar wiring
    By Andyc6845 in forum Electrical & ICE (including SatNav)
    Last Post: 23rd May 2011, 17:59
  3. Towbar wiring car has pdc
    By waltz in forum Electrical & ICE (including SatNav)
    Last Post: 19th June 2010, 20:11
  4. towbar wiring
    By dave t in forum Electrical & ICE (including SatNav)
    Last Post: 31st July 2007, 12:09
