Results 1 to 10 of 15
Thread: 2.0 dti EML light,sounds like it is running on 2 pots
    middlesbrough
    Default 2.0 dti EML light,sounds like it is running on 2 pots
    04 plate 2.0 Dti
    The spanner light comes on cuts out or sounds like it is running on 2 pots.
    Happens completely at random I turn it off and on till it starts as normal, dose this two or 3 times a day
    some time it will not start so I had to pull the a vacuum pipe out,
    And put in to limp mode to start it at last i can get where i am going.
    Had the fault readers on it and
    no fault shown each time even when it was happening.
    EGR has been off and cleaned still the same?????
    Last edited by bigmac; 5th December 2009 at 01:56. Reason: Added some engine details
    May 2008
    Derbyshire (south)
    with all due respect mate, you haven't left many details on what car you have or what engine?? How about popping onto the introdutions area & saying hi, tell us more about you & your motor/s??
    I am sure you'll receive a warm welcome there.
    I always find good manners get you a longer way tbh.
    Regular Member bigbnlr's Avatar
    Belfast
    I was waitin on this sort of reply lol
    Norwich
    Trim : SXi
    Engine : 2.2
    Its going into limp mode when the spanner light comes on mine does this only if I boot it in 5th. Turn it off and then back on and its gone and won,t do it again until I try to boot it in 5th. I have taken it to VX and had codes read and no faults I have checked all boost hoses and nothing, be interested if you find out what it is, mines a 2.2dti
    May 2008
    Derbyshire (south)
    Quote Originally Posted by bigbnlr View Post
    I thought this was quite polite of me tbh?
    Belfast
    Quote Originally Posted by mitch1965 View Post
    It was mitch, people just come here spurt off details and expect someone to produce a solution for them. Your just right imho maybe if the post had went
    Hi guy new one here and I hope someone can help me, the spanner light comes on cuts out or sounds like it is running on 2 pots and it does this completely at random I turn it off and on till it starts as normal, dose this two or 3 times a day. Its driving me crazy. Sometimes if I take a vacuum pipe out and put in to limp mode to start it at last i can get where i am going. I have tried cleaning the EGR valve and have put it on a code reader but no codes showed up. Your help would be greatly welcomed. Thanks
    May 2008
    Derbyshire (south)
    Or possibly a restriction on noobs getting into the tech side of the forum?? Maybe i'm old fashioned & have been bought up with good manners, instead of expecting something, then "off into the night" without saying thanks?? Bsd, come to mind, but then again I'm a moderator on a n other forum.
    Belfast
    Quote Originally Posted by the_wave_rider View Post
    I had this problem too I have a split in a vacuum hose. 20 second fix and good as new. The dti's are known for this mine was the white one at the front.
    Admin & Merchandise Manager bigmac's Avatar
    Devon
    67 Post(s)
    Vehicle : insignia
    Trim : irmscher
    We were all noobs one upon a time and i'm sure we've all needed help,all though he could of posted a bit more info i feel the reception he's had is far from a friendly,there's no rules stating he has to say please and thank you, all though it does go along way as stated.
    So if you's are finished with the lessons in manners maybe someone can post something a bit more constructive .
    Not picking on anyone its just the first thread ive seen since being here that's had this sort of reaction and its not what this forums about
    Irmscher Insignia CDTI 130
    May 2008
    Derbyshire (south)
    i thought i was being very friendly, not sarcastic at all, I also extended an invite too? Not alot we can say untill we have more details??
  1. DAytime running light activation
    By jon1.9cdti in forum Vectra C / Signum Car Chat
    Last Post: 29th July 2012, 22:38
  2. Replies: 3
    Last Post: 7th June 2012, 15:42
  3. help quickly, running out of light
    Last Post: 2nd April 2011, 16:44
  4. Emission light on, engine sounds rough and is weak
    By sjgore in forum Engine & Drivetrain
    Last Post: 3rd January 2011, 15:32
  5. It sounds like I'm running on a flat!!!
    By IWC in forum Suspension, Wheels & Brakes
    Last Post: 22nd July 2010, 22:22
