Thread: common problems to look for when buying
    Nov 2009
    leeds
    Exclamation common problems to look for when buying
    off to see a 05 plate 1.9 cdti sri with 65000 miles on just wondering what are the most common faults to look out for when buying cheers
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Quote Originally Posted by tez-vectra View Post
    Dual mass flywheel problems, broken swirl flaps, stuck egr's, broken springs, arb links,rear upper control arms, wheel bearings
    Hope that helps
    Look on the back, if you see "Vauxhall", that's a common problem!
    Take the car for a test drive and test EVERYTHING, lights, switches, seats, spare wheel equipment, glove box kit, etc
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    possble alternator unable to cope with load demands because of steering pump on 54 plate models and the wiper linkage on the drivers side is weak and tends to go unless it has the updated linkage.
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    Quote Originally Posted by Gazza4 View Post
    Sorry to hijack but can you tell the difference between the two linkages easily?
    Oct 2006
    Waterloo, Liverpool
    Trim : SRI NAV XP
    Engine : 1.9 CDTI 150
    Mileage : 72K
    The updated linkages have WHITE caps where they are fitted to the motor.
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Mileage : 40000
    Quote Originally Posted by john_k_sri View Post
    The newer linkages have WHITE caps where they are fitted to the motor.
    yeah thats it bud
    Gazza4
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    Cheers guys
  1. I'm looking at buying a 3.2 v6 what should I look out for known problems etc.
    By Signum-Steve in forum Vectra C / Signum Car Chat
    Last Post: 25th September 2012, 19:32
  2. Can't access 'Common Problems known to Vx'
    By Barlow in forum Vectra C / Signum Car Chat
    Last Post: 8th January 2012, 16:24
  3. recall list/ common problems
    By Tank988 in forum The 'Off Topic' room
    Last Post: 18th July 2011, 14:51
  4. Most common VXR
    By yorkshireborn in forum General Chat
    Last Post: 9th March 2009, 22:14
  5. vectra- problems or common faults?
    By fergusix in forum Vectra C / Signum Car Chat
    Last Post: 1st September 2008, 16:48
