Thread: Trip Computers On The vec
    Regular Member lutontownfan's Avatar
    Nov 2009
    colchester
    Default Trip Computers On The vec
    Hi i was wondering why there are two board computers on my sri 150 cdti one seems to work out the values slowly and gives less readings and the other works them out very fast and gives much higher readings.
    Can anyone say what this means please, cheers.
    Suffolk, Englandshire
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    You're not confusing the instant consumption display and the average consumption display, are you ?
    Nov 2009
    colchester
    Yeah quite possibly i am still getting used to all the functions in the info displays. Which of these displays gives the most accurate reading of fuel consumption? that is what i was trying to work out today.
    Nov 2009
    Norfolk
    average consumption is what the car has been getting since that section was last reset.
    Could be he last mile or the last 10,000 miles.
    Instant consumption is what the car is getting at that second.
    It will go up if you take your foot off the throttle (sometimes up to 999mpg)
    or down if you have your foot to the floor!
    Near Warrington
    999 is the injector cut of point,i.e no fuel bein used
    Nov 2009
    colchester
    So the slow readings computer would be average and the fast readings must be instant?
    Nov 2009
    Norfolk
    Quote Originally Posted by lutontownfan View Post
    Instant reading should say: Inst Cons (or similar) always changing
    Average readings should say : Consumption (or similar) slow changing
    Near Warrington
    yes thats right
    Regular Member WeDesign's Avatar
    Jun 2006
    Vectra-C.com
    Engine : CDTi 150
    Year : 55
    Quote Originally Posted by vecgsiboy View Post
    I was wondering if this is correct, because if I go down hill and take my foot off the throttle it will read 999.
    Incidently, if I put it into Neutral the reading is approx 279, so therefore my thinking was it was using more fuel.
    Mar 2007
    Tamworth
    Quote Originally Posted by DavidJS View Post
    The injectors only cut-off completely at certain points.
    Obviously, zero throttle is an absolute but the cut-off only occurs above certain revs, eg 1500rpm but could be different for different engines, otherwise the idle would be very lumpy and the cat needs a certain level of fuel to keep hot.
  1. computers going off
    By Даниил in forum The 'Off Topic' room
    Last Post: 28th June 2012, 14:46
  2. Trip computers
    By nutron in forum Vectra C / Signum Car Chat
    Last Post: 10th June 2010, 22:49
  3. anyone know about computers?
    By amar in forum General Chat
    Last Post: 26th April 2008, 10:29
  4. computers
    By lilangel in forum Comedy & Humour
    Last Post: 18th April 2008, 09:19
  5. Anybody good with computers??
    By Robward27 in forum General Chat
    Last Post: 19th October 2006, 00:45
