Results 1 to 10 of 14
Thread: wet passenger floor in 52 reg pre facelift..
    Regular Member bobby-tupper's Avatar
    LEEDS, W.YORKS
    Vehicle : 07 Estate
    Default wet passenger floor in 52 reg pre facelift..
    does anybody know the cause of a wet pass.side footwell on a 52 reg pre facelift 1800 vec c?
    Regular Member Jezzy's Avatar
    S.E
    Most obvious thing would be a blocked drain plug near the pollen filter; on some other makes of cars dodgy A/C can cause wet n/s floor as well.
    Regular Member Terry Tibbs's Avatar
    Aug 2007
    with all this rain i'd go with the drain plug mate, think it can be a common prob, have seen it mentioned on here a few times.
    Full Member Big Sig's Avatar
    Search Button!
    asdasd
    ok i get this same issue..I dont know what to put in the search box to find the problem..How do i fix this.. THANKS
    asdasd
    FOUND IT thanks
    Suffolk, Englandshire
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    Quote Originally Posted by vec3.2 View Post
    Open bonnet... locate meshed/slotted area of scuttle area to the front of passenger side of windscreen.... gently lift off rubber seal that overlaps forward edge of scuttle panel.... this will permit you to lift the portion of the scuttle that cover the cabin air intake/pollen filter.
    Use a torch and look straight down this 'chamber' forward of the pollen filter and toward the centreline of the car..... when dry you can see the rubber drain liner that tends to get clogged.... when wet, find something long, thin and stiff, yet flexible to poke about to try and clear the drain.
    "Water footwell" would do it.
    FOUND IT thanks
    Cool, I would have posted a link but I was at work
    LEEDS, W.YORKS
    Vehicle : 07 Estate
    when the drain is blocked the water finds its way into the car....... so where does the drain,drain to? if that makes sense?
    its not my motor, its a woman who works at the salon for me, but i get shafted with all her car repairs.
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    It just drains to the grounds mate. If the footwell is wet then she may start getting heater problems. VX's fix was to just drill a hole in the bottom of the fan housing until they brought out a revised design.
  1. passenger side floor soaked
    By MORGIE8153 in forum Vectra C / Signum Car Chat
    Last Post: 17th September 2010, 15:00
  2. wet floor on passenger side
    By vinceverrier in forum Bodywork & Interior
    Last Post: 5th September 2009, 13:20
  3. Retro-fitting pre-facelift passenger door switch to facelift
    By greeningr in forum Vectra C / Signum Car Chat
    Last Post: 23rd May 2007, 15:58
