Thread: Oil level light
    Liss
    Vehicle : Astra (J) Sports Tourer
    Trim : SE
    Engine : 2.0CDTi 165bhp (S/S)
    Default Oil level light
    The yellow oil level light comes on intermittently on my 08 SRi VVT.
    The oil level is OK (just under Max)
    Could this be the sensor playing up?
    I still have 2 months left on the NetworkQ warranty, so could be a trip to the dealers to get it sorted, before it runs out.
    Full Member Robsey's Avatar
    North East Cheshire
    23 Post(s)
    Trim : Energy
    Mileage : 131,000
    Two possible causes: -
    The pressure switch is sticking / defective - needs replacement.
    or
    Oil sensor wire may be chaffed by moving part in the engine bay, thus sensor wire is shorting out - need loom repairing.
    Unlikely to be faulty oil pump unless your car has high mileage...worn pumpwould produce lower oil pressure.
    If it's still under warranty, should be cheap repair for them, so should be no quibble from network q.
    Liss
    Trim : SE
    It's only done 26000 miles and it's 2 years old next March. I had it since January this year and have covered 15000 so far. No other problems.
    Looks like I'll be booking it in
    Thanks for the advice
    Quote Originally Posted by Cannonball2 View Post
    If its on Network Q, then ironically the 3 year warranty will expire first!
    The covers the car up to 60K miles
    Your car will still be under warranty until its anniversary in 2011
    However, book the car in so that the fault is at least logged
    If it comes back in the future you can refer back to it if the dreaded "no fault found" occurs
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    If the yellow oil level warning is activating, then it is not an oil pressure issue.
    I assume your engine is the 1.8, and my 1.8 has an OLS in the front side of the sump. It is totally different to oil pressure sensing and shouldn't be confused. Maybe this sensor / wiring is defective.
  1. Oil level warking light & help
    By Chip in forum Engine & Drivetrain
    Last Post: 4th December 2012, 19:12
  2. Oil light and water level light on and off :S
    By Wrig in forum Engine & Drivetrain
    Last Post: 22nd August 2012, 15:34
  3. Is this a low oil level light?
    By krazylegz in forum Vectra C / Signum Car Chat
    Last Post: 7th May 2012, 19:31
  4. Oil Level Light????
    By SomeboyMartinJ in forum Engine & Drivetrain
    Last Post: 3rd December 2011, 21:28
  5. Low Level Oil Light
    By rocket999 in forum Engine & Drivetrain
    Last Post: 8th August 2011, 01:40
https:www.vectra-c.comforumshowthread.php96669-Oil-level-light
vectra c 1.8 oil light
opel vectra c oil level lamp fail
engine oil level opel vectra c
