Page 1 of 4 123 ... LastLast
Results 1 to 10 of 32
Thread: Spanner Light but no Limp Mode
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    Default Spanner Light but no Limp Mode
    As above what does it mean when there is the spanner and car light is no limp mode.
    I have had the manifold replaced in June and the swirl flaps work as i can see the rod move whan a m8 presses the accelerator.
    Is this just a fluke - car drives as normal though
    Gazza4
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Light on all the time bud or just when started or.....?
    Nov 2009
    northants
    mine comes on when i start it after about 30 sec it goes out or back to bulb out sign even thow there all working
    Scotland
    Could it be the service indicator, My dad'd '06 Altea shows a spanner for about 30seconds Then Disappears when it's due for a service.
    Regular Member sdemps's Avatar
    Nov 2007
    Ayrshire
    Mine does crazy stuff like that. Light on driving fine after about 10 miles went back off. Luckily i have a fault code reader. It showed up a throttle actuator fault.
    Need to get it read to see what yours is!
    Norwich
    Trim : SXi
    Engine : 2.2
    Mine does it if I boot it in 5th then when i switch engine off its gone until next time I try to boot it in 5th if I change down no probs at all. Had it read and no faults shown. Get it read is the only way to check it really
    Mar 2007
    Tamworth
    Having read the book like an anorak, the light is also used to indicate water in the fuel.
    Nov 2009
    west mids
    I had the spanner light on, as mentioned here, it was water in the fuel. There is a drain on the bottom of the fuel filter housing, just unscrew it anti-clockwise and let some water/fuel drain out, nip it back up and drive, see if the light goes out.
    11 Post(s)
    Quote Originally Posted by rbsnGaGa View Post
    Could it be the service indicator.
    No!
    Car/spanner is the ecu fault light, autobox fault light, and immobiliser fault light.
    Service light is either an oilcan/spanner light, or the word InSP in the odometer display when the key is first turned.
    Regular Member PAULMAC77's Avatar
    warrington
    Quote Originally Posted by lee58uk View Post
    just a thought but check your brake lights, look closely and see if one is lower than the other, cos what it does if your brake light bulb blows it uses your sidelight as a temporary measure so you still have 2 brake lights.. this happened to mine...
  1. 04 2.2direct spanner light and limp home mode
    By ScottyV6 in forum Vectra C / Signum Car Chat
    Last Post: 4th June 2011, 13:45
  2. 2.2 DTi spanner light and limp mode only at motorway speed
    By cont1204 in forum Engine & Drivetrain
    Last Post: 31st May 2011, 19:30
  3. limp home mode but no spanner light??
    By mick 1986 in forum Engine & Drivetrain
    Last Post: 5th April 2009, 12:22
  4. Replies: 33
    Last Post: 30th December 2008, 19:08
  5. spanner light on 2.2 dti and goes in to limp mode
    By thelad in forum Engine & Drivetrain
    Last Post: 14th March 2008, 21:48
vectra c car and spanner no limp mode
