Thread: Fault code P0243 (1.9CDTI 150) Turbo wastegate...
    Regular Member danBoy's Avatar
    Jun 2006
    Northampton
    Default Fault code P0243 (1.9CDTI 150) Turbo wastegate...
    I'm trying to sort out a correct part for a customer, now the fault code is coming up P0243 which is to do with the Turbo wastegate etc.
    Any ideas what part I'll be needing to supply??
    The actuator at a guess
    Jun 2006
    Northampton
    Hmm can find reference to the pipes that go on it but can't see the wastegate actuator listed unless it comes part of the turbo.
    Edit - Unless its the vacuum sensor for the Turbo??
    Could be as its controlled via a vacuum on the petrol. Guess its electronic on a diesel? which could lead to something else???
    Jun 2006
    Northampton
    No probs thanks for your help, I think I've narrowed it down now.
    West
    Boost pressure valve high voltage
    Regular Member larrysSRI's Avatar
    Nov 2009
    south wales
    just out of interest what are the symptoms the customer is having?
    Jun 2006
    Northampton
    Quote Originally Posted by larrysSRI View Post
    I'm not too sure, shes just got a bit of paper with the codes it came up with. Car was diagnosed by the local garage.
    Just trying to get my head round it
    Jul 2010
    manchester
    P0243 = Boost pressure valve low voltage. could be anything. turbo, wiring loom, bad fuel, inlet manifold, wastegate, injectors, ECU, electric mirrors. sorry, just ****ed off, looks like mine needs a turbo at 90k on a 56 plate. vanes stuck. found out today. VX should recall all of these and supply a new engine that works.
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    vx do a recall Ha Ha!!!, they only do what there forced to do or told to do because of safety issues, there not interested in anything else unless there pushed into it.
  1. 2.0t turbo fault code P0034
    By loonyone in forum Vectra C / Signum Troubleshooting
    Last Post: 17th April 2018, 21:04
  2. Signum turbo wastegate help
    By redryan in forum Engine & Drivetrain
    Last Post: 18th February 2013, 21:46
  3. Limp mode on my 2.0 dti and fault code is p0243.
    By dazza2393 in forum Engine & Drivetrain
    Last Post: 20th September 2012, 20:57
  4. How to make my 1.9CDTi Wastegate Chatter
    By dannybl1990 in forum Diesel Engine related
    Last Post: 19th June 2012, 02:50
  5. I Need a Fault Code Reader for 06 1.9cdti
    By thefibreguy in forum Diesel Engine related
    Last Post: 31st May 2010, 18:44
vauxhall vectra fault code p0243
p0243
Opel DTC P0243-04
p0243 vauxhall
p0243 zafira code
p0243 vauxhall fault code
opel p0243
p0243 opel
1.9 dth turbo faulty wastegate actuator
p0243 fault code astra h cdti
vauxhall astra 1.9cdti fault code p0243
opel zafira p0243
turbo vane 1.9dth sticking
Vauxhall DTC P0243-11
p0243 zafira
vauxhall astra van dtc P0243
p0243-11 opel
vx corsa d 1. fault code p0243-11
astra h p0243
p0243 - boost pressure valve low voltage
code reader for vauxhall astra p0243
Z13dtj P0243
Vauxhall P0243
vauxhall vectra turbo diesel wastegate
vectra c 1.9 cdti wastegate blocked
