Results 1 to 10 of 22
Thread: Traction control on an 04 sri-how easy to fit ?
    Regular Member Fash's Avatar
    Doncaster
    Default Traction control on an 04 sri-how easy to fit ?
    As the title says-how easy is it to fit traction control into an 04 sri (cdti 150). Seems to have a few issues slipping on the roads every now and then (don't think it's my driving ALL the time, LOL). Also how much to do it ?
    Thanks,
    Steve
    Lancashire
    Vehicle : Vectra SRi
    Trim : XP1
    Engine : 1.9 CDTi 150
    Mileage : 66000
    Have you tried the switch...? (£15ish from VX)
    Doncaster
    No mate, does it have the wiring already in place like some models do and it's just a case of connecting the switch to the wiring ?
    Regular Member P3tchy's Avatar
    Milton Keynes
    Should have it all in place just need the switch pn 13138265 £11.30 from a dealer.
    Mines an 04 SRI CDTI 150 and it went straight in and is working.
    Lancashire
    Trim : XP1
    Mileage : 66000
    Quote Originally Posted by Fash View Post
    There is a plug behind there yes, but some work and some don't, but even if it doesn't, you'll have a nice new switch that lights up.
    milton keynes
    I thought that all vectra's had traction control and the switch is to turn it off.
    Doncaster
    Nice one-I'll get that part ordered soonest
    Lancashire
    Trim : XP1
    Mileage : 66000
    Quote Originally Posted by kman247 View Post
    Alot of Vectras have TC, but no switch to turn it off.
    Jan 2008
    NW - Cheshire
    By installing the switch you will only add the function to switch off traction control!
    You could check the fuse is ok, but I would have thought if the fuse had blown you'd have warnings on the dash?
    milton keynes
    I thought all of them , was just really responding to the original question , so you dont need a switch for traction control as it already there.Best thing is to check the ABS ECU if you put pin 3 (if i remember correctly) to ground and it displays the icon on the clocks , you can have TC disabled. The option you have if the switch doesnt turn off the TC , you can get another ABS ECU.
  1. Rear Control Arm Bush Replacement Made Easy
    By Rebellion in forum Vectra C / Signum Car Chat
    Last Post: 6th June 2012, 16:29
  2. traction control
    By neill in forum Vectra C / Signum Car Chat
    Last Post: 7th September 2010, 10:55
  3. Traction Control
    By wotsthestory in forum Vectra C / Signum Car Chat
    Last Post: 31st December 2009, 12:38
  4. traction control
    By ryanhamil in forum Vectra C / Signum Car Chat
    Last Post: 6th August 2008, 22:39
  5. Esp & Traction Control
    By andy.l in forum Vectra C / Signum Car Chat
    Last Post: 7th May 2007, 17:21
https:www.vectra-c.comforumshowthread.php96637-Traction-control-on-an-04-sri-how-easy-to-fit
