Results 1 to 10 of 16
Thread: Cats pee smell
    Regular Member cabbage's Avatar
    Bristol
    Default Cats pee smell
    Occasionally get a smell like cats urine in the car when driving. It comes in quite strong suddenly and then gradually goes away. Can happen at any time. Does it mean there is a hose leaking or getting too hot? The air con was flushed a couple of months ago when I had the car serviced. I'm not over revving or anything but could it be the clutch slipping? Didn't feel like it.
    May 2007
    West Yorkshire
    Might be the catalytic converter?
    May 2008
    Derbyshire (south)
    Have you checked that the drain trunk is clear & you don't have mini bath at the bulhead? Is your passenger footwell dry?
    Regular Member bobby-tupper's Avatar
    LEEDS, W.YORKS
    Vehicle : 07 Estate
    it just be a cat wazzing on the front of your motor and its gone on to the radiator, hence the smell
    Regular Member SignumPhil's Avatar
    Luton, Beds
    I had a similar problem when a moggie used to pee on one of my front wheels. First time I braked in the morning, you'd smell it.
    A good clean with alloy wheel cleaner stopped it -they don't like the smell of acid!
    Phil
    Feb 2007
    North west
    We used to have a plant pot by the front door that must have been the dividing line for neighbors cats as they both marked the spot. I think your car might be the same thing. A super soaker can be a solution - a couple of squirts and they soon learn.
    hull
    is it when you've just used your windscreen washers by any chance, mines the same!!
    glasgow
    cats also go under the cars for a heat ,and same here i have two female cats and the male cats come round and spray everything especialy the car
    Regular Member graham a's Avatar
    hull
    Quote Originally Posted by frasedeb View Post
    same hear
    Nov 2009
    northants
    check Air con !
  1. Cats!!!!
    By Jow20 in forum Vectra C / Signum Car Chat
    Last Post: 21st January 2011, 20:30
  2. Cats
    By GazVXLINE170 in forum General Chat
    Last Post: 10th May 2009, 23:47
  3. While the cats are away !!!!!!
    By Drinky in forum The 'Off Topic' room
    Last Post: 6th April 2008, 17:34
  4. Mad cats!!!
    By Mrs D in forum Comedy & Humour
    Last Post: 14th October 2006, 11:08
  5. Cats!
    By ukanalyst in forum Comedy & Humour
    Last Post: 13th August 2006, 09:44
