Thread: One for you electrically minded...
    Hanging Heaton / Batley
    18 Post(s)
    Trim : SRi (VXR Styling)
    Engine : Z19DTH (Re-mapped)
    Mileage : 110k
    Question One for you electrically minded...
    On half canbus, can you hard wire to the cig lighter and interior light?
    Where else also without any issues? cheers...
    Regular Member benny's Avatar
    Feb 2006
    dudley
    yes ..the loom that feeds the light is hard wired so no canbus related to the bulbs and power feeds (just the switch on and off process) ..but the loom for the light is a flat band type that goes to the rear of the car ...seems silly to run a wire into the roof via the pillers .....would be best to look for a feed in the dash area ....
    Jul 2009
    The Rift, Cardiff
    I found it better to wire a direct feed from the battery through a groomet. Makes it easier if a fuse blows, and you can use the cheaper standard size. Plus less fuss if you need to add more toys, I mean usefull gadgets
    Full Member Robsey's Avatar
    North East Cheshire
    14 Post(s)
    Trim : Energy
    Mileage : 131,000
    Depending on your needs, you could run a live feed from the boot.
    There are threads on here about fitting a permanent live supplementary socket in the boot / load area or for changing the lighter socket feed so that it does not turn off after five minutes.
    Also the lighter sockets and interior lighting are indeed controlled via the can bus system (BCM and REC) - body control module behind the glovebox and the Rear electronics centre in the near side wing of the boot.
    18 Post(s)
    Mileage : 110k
    Was thinking of running from the interior light just for footwell lights, so they come on with when locked/unlocked and interior light on... did similar with the astra...
    Hard wired will come from the boot for other future bits, anyone any links or info on where to take it from?
  1. Any engineers / mechanical minded people ?
    By poves in forum General Chat
    Last Post: 9th May 2012, 22:13
  2. what are the downsides of electrically disconnecting EGR valve on the 150 CDTi
    By wickedwillie in forum Vectra C / Signum Car Chat
    Last Post: 11th March 2012, 12:46
  3. Problem with Electrically adjustabale front seats
    By Downunder in forum Electrical & ICE (including SatNav)
    Last Post: 15th June 2009, 21:06
  4. Electrically Folding Door Mirrors?
    By joejdx in forum Vectra C / Signum Car Chat
    Last Post: 13th February 2009, 16:32
  5. Any clever ipod bods on here? or electrical minded people
    By robhullfury in forum General Chat
    Last Post: 31st August 2007, 10:14
