Thread: 3.0 V6 CDTi Left Indicator Staying On, Help!
    Oct 2009
    Belfast
    Default 3.0 V6 CDTi Left Indicator Staying On, Help!
    Hi Everyone, first post on here, although I have read many posts and gained a lot of help from here, great site, great work people!
    I would be very grateful if someone can help me as I am all out of options. I have a warning light which states 'check left parking light'. I replaced the parking light thinking this would solve everything, I was wrong. The parking light (small push in bulb) now works fine but the indicator light directly above it remains on. Even when full beam is on the indicator light stays on. All other lights seem to be working and the indicator actually flashes when I push the stalk down to turn left.
    The only time the indicator light goes off is when I indicate to go right, otherwise it is on constantly??
    Anyone else had this problem? Easy fix? Fuse or something simple please?!
    Thanks for your responses in advance.
    What MY is the car?
    If the front head lights fail then the system puts the indicator on to compensate (thankfully mine doesn't do this)
    If you have already changed the side light bulb, does the replacement work?
    I suggest you switch on ALL the lights, then walk round the car and check each one
    Oct 2009
    Belfast
    Hi, its an 04 Vectra. I have checked all of the lights and they seem to be working fine, checked each one individually and the new parking light bulb which I fitted seems to work fine also.
    Any other suggestions?
    The CIM module may have failed
    This really needs an autoelectrician to diagnose
    Jun 2007
    Black Country
    Take the new bulb out and swap with the drivers side, see if your drivers side indicator stays on, if so, its a duff bulb
    Firstly RTFM, then do the aboe and make sure all the connections are clean in the lamp holders.
  1. Left indicator flashing fast, front indicator not working
    By Hummelshøj in forum Electrical & ICE (including SatNav)
    Last Post: 7th August 2017, 14:42
  2. left indicator flashing fast
    By bigpaul08 in forum Electrical & ICE (including SatNav)
    Last Post: 24th June 2012, 11:22
  3. OS Indicator (front and side) staying on
    By no_mates in forum Electrical & ICE (including SatNav)
    Last Post: 19th March 2012, 20:53
  4. boot and rear left indicator not working
    By lander7394 in forum Electrical & ICE (including SatNav)
    Last Post: 27th June 2011, 20:12
  5. Left indicator and right main beam not working(help)
    By kalim in forum Electrical & ICE (including SatNav)
    Last Post: 9th December 2009, 14:10
vectra c indicator stays on
vectra c rear left indicator bulb staying on
