Thread: Spanner light when driving plus gear problem
    Horley
    Default Spanner light when driving plus gear problem
    Hi everyone, at the weekend I drove from surrey to cornwall, on the way back yesterday we stopped at the tamar bridge to pay the toll when pulling off again there was a thump from the engine/gearbox. The car pulled off then the spanner light came on, the car seemed to be driving fine, I carried on driving and got onto the M5 we pulled off at membury services when we slowed down, we had to speed up a bit the car seemed to be stuck in high gear, I parked turned off the engine, started it again and switched to manual mode, the display would only show 3rd and 5th gear. We turned off and left the car for about 1 hour. When we returned we started the car the spanner light had gone and the car drove fine and changed through the gears with no problems, the light stayed off as we drove the further 150 miles with no problem. The car is fine today. Any one got any ideas what can cause this. many thanks
    Last edited by pach1962; 2nd December 2009 at 20:06. Reason: car is vectra 2.2dti ellegance auto
    11 Post(s)
    The fault code should be stored for a period of time before it self deletes. Easiest thing to do is to get the fault code read out - beats guessing what the problem was.
    Jul 2009
    sussex
    first thing i would do is check the auto box fluid is topped up enough, then go for the fault codes.
    Regular Member carpet's Avatar
    Jul 2006
    TENTERDEN KENT
    As well as checking the box fluid have a look at the colour of it as it may be burnt for some reason.
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    Engine : 140 Ecoflex S/S
    From what you've described and referring to VX TIS2000 "No or incorrect shifting function. Fault codes P0700, P0715, P0720 (separate or together) stored", I'd go for "Faulty transmission input/output speed sensors signal due to moisture inside the sensor" as per VX field remedy 1685.
    HTH
    Wellington
    I would agree with gtr1000.................been there with it!!!
    hope your rich!!!
  1. Spanner light while driving to work with no code and usually same point when driving to work?
    By rollercoaster63 in forum Vectra C / Signum Troubleshooting
    Last Post: 6th July 2012, 21:52
  2. Spanner Light on for the first minute of driving.....
    By focus_driver in forum Engine & Drivetrain
    Last Post: 20th November 2009, 19:44
  3. spanner light whilst driving
    By porthy-t in forum Engine & Drivetrain
    Last Post: 8th November 2009, 17:27
  4. Spanner Light Problem
    By levy9 in forum Engine & Drivetrain
    Last Post: 23rd August 2009, 14:39
  5. Yellow spanner light when driving....
    By mpc in forum Vectra C / Signum Car Chat
    Last Post: 28th July 2009, 08:18
