Thread: Insignia VRX Brakes on a Vec...?
    Regular Member Jezzy's Avatar
    S.E
    Default Insignia VRX Brakes on a Vec...?
    The Insignia VXR has Brembo 4-cylinder brake calipers with 360 mm diameter disks on the front; has anyone done the maths on whether they would fit on a Vec/Signum? Not considering it for my car as I'm sure it would cost an arm and a leg, but would be good to know just out of idle curiosity.
    Regular Member danBoy's Avatar
    Jun 2006
    Northampton
    Its possible although the discs won't just bolt on, and I bet they aren't cheap either
    S.E
    Quote Originally Posted by danBoy View Post
    ....Except for you with your 95% LMF-staff discount...
    Jun 2006
    Northampton
    I wish although I have been spending far too much lately
    Leicester
    The answer is a simple................no chance.
    Vectra has a 5 x 110 stud pattern.
    Insignia has a 5 x 112 stud pattern.
    The PCD of the calipers where they bolt on to the strut is also different. So it would not even be worth modifying them to fit. It would be cheaper to buy a different kit from Brembo/Hi-Spec/AP Racing/Willwood.
    Regular Member evyboy's Avatar
    Jul 2009
    hamilton
    As maverick says, you would probably be cheaper buying 6pot ap racing brakes, and they are just as big, they fit and probably work just as good if not better
    Nov 2009
    Quote Originally Posted by Maverick View Post
    Would "wobbly" bolts not work?
    Why've Vaux changed to 5 x 112... For as long as I can remember they have been 5 x 110.
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    They aren't 112 they are 5x120, same as bmw
    Quote Originally Posted by ScottR View Post
    I'd assume because everything is a lot bigger on the insignia...
  1. insignia vxr brakes
    By brod999 in forum General Motoring Chat
    Last Post: 24th December 2012, 15:21
  2. The Insignia SUV and the Facelift insignia
    By Caveman_nige in forum Insignia car chat
    Last Post: 2nd November 2012, 01:21
  3. Replies: 14
    Last Post: 3rd September 2011, 20:23
  4. Insignia VXR Brembo Brakes
    By Maverick in forum Insignia car chat
    Last Post: 14th May 2010, 20:17
  5. Brakes
    By nikroc in forum Vectra C / Signum Car Chat
    Last Post: 27th March 2008, 12:16
