Results 1 to 3 of 3
Thread: Air Circulating Button !!
    Sep 2009
    Belfast
    Default Air Circulating Button !!
    I've a basis 2008 1.8vvt Life Estate - everything is optional !!!
    Should my Air Circulating button work !!!!
    The other 3 buttons work and the yellow LED lights - nothing happens when I push the Air Circulating Button & yes I have the fan on.
    Is this another optional extra !! if not should it not operate when the main fan is on!!
    Lastly if it should function, then would this be covered under VX 3-year warranty.
    The car has 20k miles and was serviced by a franished dealer (non-VX) after 14months.
    Thanks in advance.
    Sep 2009
    Belfast
    It works !!!
    I had the "HEATING & VENTILATION" switch set to position 3 (WINDOW & FRONT DOOR). It seems to work in every other position apart from 3.
    How stupid I'm I not to have worked this out before posting !!!!!!!!!!!!
    Yes, you don't want the recirculate on when the airflow is pointing at the windscreen.
    1. it will mist up instead of demist the screen.
    2. I believe the recirculate mode uses the windscreen vents to draw in the air for the blower.
  1. Boot Button vs Lock Button
    By Leemarksmith in forum Vectra C / Signum Car Chat
    Last Post: 28th January 2013, 21:30
  2. sport button, traction control button
    By Denbro in forum Vectra C / Signum Car Chat
    Last Post: 26th March 2012, 23:44
  3. ESP Button?
    By KSD in forum Vectra C / Signum Car Chat
    Last Post: 28th July 2009, 20:04
  4. re-circulating dump valve
    By spooney in forum Petrol Engine related
    Last Post: 13th March 2009, 21:24
