Results 1 to 10 of 14
Thread: B1000 airbag fault - what would you do?
    Nottinghamshire
    Default B1000 airbag fault - what would you do?
    The airbag fault came on yesterday and has been read with a Tech2 as B1000 - see below.
    B1000 replace the control unit - EEPROM errors C-002
    B1000 replace the control unit - hardware errors C-002
    B1000 control device to replace C-002
    B1000 control device malfunction C-002
    The guy who read the code said this could be the airbag control module or the CIM. Does anyone know if this is the case or if it is definitely the airbag controller?
    Also, who would you trust do get it fixed? Dealers want £580 for a new airbag controller (if that's what it is). I have seen places that will repair the existing module for under £100 which is very tempting butI'm not sure if I'd trust them to get it 100% right. Perhaps the price seems a bit too cheap for repairing a box of electronics, especially one that could save your life.
    Regular Member Keithy's Avatar
    Jan 2008
    Dundee
    you just answered that yourself mate. when it comes to something like that which might save you life one day, i'd trust the dealer and no one else
    Mileage : 000
    Do you move your driver,s seat back and forth offten, as that daft as it may sound can make the airbag light come on. It sounds like it might just need resetting, as there may not be an actual fault with it.
    Nottinghamshire
    Quote Originally Posted by ed taylor View Post
    Thanks. I don't move the seats much, but the garage checked just in case one of the connectors had come loose and also tried clearing the code - but it is one that you can't clear.
    There are different fault codes for sensor and airbag errors and also for if the airbag controller has trouble communicating with any of them (cabling issues as you suggest). Unfortunately, B1000 relates specifically to a hardware fault within the controller itself.
    Someone said it could also be the CIM and I hope someone can confirm if that is the case or not...
    Nottinghamshire
    The second garage (full dealer this time) confirmed the B1000 fault code means a new airbag ECU.
    I have been quoted £540 and the car is booked in on Monday morning because I've got no airbags until it's fixed.
    I am hoping to get the quote down to nearer £500 because I have stripped out all the centre console and will also put it back in myself. The dealers system gives 1 & 1/2 hours for the job and I'm sure that over 1/2 an hour of this is to remove and refit the centre console.
    DERBY
    had northern autotech swap my data in to another ecu got it back today and light still came on , when I spoke to him he said it could be the CIM any ideas fellas getting realy pd off with this car now has anyone had this code and it turned out to be the CIM dont want to spend £800 on a car thats worth £1500
    Nottinghamshire
    There are quite a few airbag fault codes but I think that the ECU turns the light out when the disappear, with the exception of an airbag activation which causes the light to stay on until the ECU is replaced or re-set (depends on the model of ECU and who does it).
    Code B1000 relates specifically to an internal fault with the airbag ECU so if B1000 is still the code you have then the issue is most likely to be with the ECU.
    Maybe this means that the previous fault (or a new one) is present or there are (still) issues with the ECU, so perhaps a fault code read would be a good idea so you know what you are aiming for unless you have already done this.
    Was the new ECU programmed with the correct specific code and also set the match the number of airbags and seatbelt pretensioners in your car?
    Administrator plasma's Avatar
    On the Forum
    409 Post(s)
    Engine : 150
    Mileage : 74000
    Sometimes when an ECU comes back from repair/reset it will still need the generic airbag codes clearing.... Was the same with mine. Had mine sent away for repair, came back and just had to clear the fault codes. Then it was all hunky dory
    Nottinghamshire
    Quote Originally Posted by plasma View Post
    What model of airbag ECU do you have? Shaper and me both have early Vectra C's and so both have the original airbag ECU. I think the original model was not re-settable via a fault code reader but later ones were.
    On the Forum
    409 Post(s)
    Engine : 150
    Mileage : 74000
    it was on a 54plate full can car.. I wasnt talking about clearing 'crash' codes, just normal codes like pretentioner open circuit, or quib high resistance.. Had a couple of these type of codes on mine.
  1. Airbag Fault Codes
    By dudley6623 in forum Vectra C / Signum Car Chat
    Last Post: 19th February 2013, 00:49
  2. airbag fault
    By veccyv6 in forum Electrical & ICE (including SatNav)
    Last Post: 28th August 2012, 16:35
  3. what would cause all these airbag fault codes?
    By krazylegz in forum Electrical & ICE (including SatNav)
    Last Post: 25th April 2012, 18:36
  4. Can someone please help. AIRBAG FAULT
    By Bigg943 in forum Electrical & ICE (including SatNav)
    Last Post: 14th July 2011, 22:32
  5. Airbag ECU fault
    Last Post: 2nd February 2011, 23:22
Opel B1000
b1000 ecu malfunction
b1000 vauxhall
b1000 opel
b1000 airbag code
vectra c airbag b1000
b1000-00 opel
B1000 airbag ecu malfunction
code B1000-49
b1000 fault code opel
Vauxhall B1000
b1000 srs code w220
SAAB B1000
b1000 code toyota
B1000 opel vectra c
Opel DTC B1000-00
b1000 toyota aygo
Peugeot DTC B1000
codigo B1000 corsa
b1000 code
vectra c b1000
Opel DTC B1000-39
b1000 opel astra
vectra fault b1000
astra h Electronic Control Unit EEPROM PerformanceMalfunction
