Results 1 to 10 of 14
Thread: Please recommend me the best oil
    Kingston Upon Hull
    Default Please recommend me the best oil
    Please recommend me the best oil for my 150 cdti vectra c
    I only do about 10,000 miles a year
    all short trips to work and back + the odd trip at the weekend
    i would like to use V/hall oil
    Thankyou Jacko
    Lancashire
    Vehicle : Vectra SRi
    Trim : XP NAV
    Engine : 1.9 CDTi 150
    How many miles has your 2004 CDTi got mate..?
    Mileage : 000
    I put Mobil 1 in mine.
    Kingston Upon Hull
    Hi my car has done 30,000 + miles
    Kingston Upon Hull
    The garage that is going to service the car for my wants to know if i want long life oil or standard oil if long life it will be £20more is it worth it
    Jacko
    Ps i was going to service my car but have just had a hernia op
    Regular Member hairy31's Avatar
    Jun 2009
    bradford
    go to national tyres = castrol edge 0/35 oil and filter change £35 inc......not worth getting under car for IMO..........hope that helps
    Andy
    Lancashire
    Trim : XP NAV
    Thats low mileage for a 2004
    Regular Member ANDY W's Avatar
    May 2007
    WINSFORD
    I have always had Vx own Fully Synthetic 5/30 as that is long life and very reasonable really.
    Lancashire
    Trim : XP NAV
    As mine has crept over 70K I have switched to Mobil 10/40 Semi Synthetic and its better for it, but for your mileage then the fully synth will be fine, but not long life, as you shouldn't leave oil in that long anyway
    Full Member fikse's Avatar
    Apr 2009
    Bergen, Norway
    Especially since you drive so little (ill guess you have several small trips?) its even more important that you stick with a good oil. Several small trips stress the engine and oil more than long trips. Its also the cold-starts that really wear the engine at most, in normal situations.
    The OEM GM 5W-30 is a good quality oil, able to handle more deposits than the simpler (10-40?) oil.
    There will always be a discussion wether this or this oil is the best, and there is nothing wrong by using another brand oil. But the viscosity 5-30 is a good choice for most small car engines used in Europe, and AFAIK the GM is actually made by Fuchs, who is well known to make no-nonsense, value-for-money, products.
    So if it isnt huge price difference between the OEM GM and other fully syntetic 5-30 oils, you should consider stick to GMs. Here in Norway, the OEM oil is actually the cheapest "sertified" GM longlife oil I can get!
    PS: Just forget about the longlife term. For your case I would change the oil (incl filter) at least once a year.
    Bent, my name is Bent
    Mods: I polished it in september...
  1. Recommend me a..............
    By keith1983 in forum Electrical & ICE (including SatNav)
    Last Post: 17th December 2011, 16:56
  2. Recommend a re-map
    By rockonoli1 in forum Vectra C / Signum Car Chat
    Last Post: 15th July 2011, 00:12
  3. Recommend my mum a new car!
    By djr69uk in forum The 'Off Topic' room
    Last Post: 19th May 2011, 18:43
  4. Recommend me an oil
    By lizard in forum Engine & Drivetrain
    Last Post: 4th December 2009, 14:11
  5. anyone recommend a hid kit?
    By EURO G in forum Vectra C / Signum Car Chat
    Last Post: 9th April 2008, 23:11
