Results 1 to 2 of 2
Thread: Vectra C 1.9 cdti oil leak
    Regular Member brad69bj's Avatar
    Jun 2009
    Leeds
    Angry Vectra C 1.9 cdti oil leak
    Hi, can anyone help? My vectra 1.9 cdti is constantly leaking oil from the drain on the oil filter housing. I have changed the filter a couple of times and it still leaks??
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    are you changing BOTH sealso-rings on the cap when changing the filter, sounds like the oil is leaking past the first seal/o-ring, if you are make sure you try a genuine filter and see if that works.
  1. Oil leak 150 cdti oil leak help
    By sr_fly in forum Vectra C / Signum Car Chat
    Last Post: 14th July 2011, 20:46
  2. Vectra C (2004 1.9 cdti) black smoke, no turbo, air leak HELP!
    By baldieone in forum Vectra C / Signum Car Chat
    Last Post: 30th July 2010, 20:54
  3. Replies: 5
    Last Post: 29th July 2010, 13:51
  4. Vectra cdti 120 bhp. Air Leak? Turbo lagging?
    By colin IC in forum Diesel Engine related
    Last Post: 12th March 2010, 19:22
  5. 1.9 CDTi Oil leak
    By GSiSnash in forum Engine & Drivetrain
    Last Post: 20th May 2008, 19:07
vectra 1.9 cdti oil leak
vauxhall vectra 1.9 cdti oil leak
1.9cdti oil leak
http:www.vectra-c.comforumshowthread.php96550-Vectra-C-1-9-cdti-oil-leak
1·9 cdti oil leak
vectra c cdti oil filter drain pipe www.vectra-c.com
oil leak Vectra c 1.9 cdti
zafira 1.9 cdti oil filter housing leak
oil leak in vauxhall vectra 2005 1.9
have oil leak in vauxhall vectra 2004
vectra cdti oil leak
vauxhall vectra oil leak
oil leak vectra c 1.9cdti
vauxhall vectra ocdti il leak
07 vectra 1.9cdti oil leak
