Thread: cold running problem
    Sep 2009
    goole
    Default cold running problem
    wondering if any one else has this,when cars frist started up cold and drove its realy flat with no go in it till nearly 2000rpm the car is a1.9cdti sri vectra c its like it in 1 2 3 gears only when cold any thoughts cheers
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    The CDTI's actually perform better in cold weather due to the slightly higher air density. If it unresponsive in low revs in cold there may be an egr issue.
    Gazza4
    Regular Member Keithy's Avatar
    Jan 2008
    Dundee
    i run a 2.2dti and its the same. but i rarley cane it when cold. its probably got something to do with the viscosity of the oil when cold
    West
    The ecu on the 1.9cdti will not allow you to cane it until the engine has reached a reasonable working temp... it's meant to prevent you from killing the motor.
    & oh yes all turbo cars, petrol or derv prefer the cold weather
  1. Quick one.. Running cold
    By goafer in forum Engine & Drivetrain
    Last Post: 6th December 2010, 07:09
  2. Running Cold
    By dc6839 in forum Bodywork & Interior
    Last Post: 29th November 2010, 18:43
  3. Running too cold
    By crgv6 in forum Engine & Drivetrain
    Last Post: 25th February 2010, 20:18
  4. Cold running on 1.8 vvt
    By jasone in forum Engine & Drivetrain
    Last Post: 7th December 2008, 15:28
  5. 3.2 V6 Gsi Rough Running From Cold
    By TOON VECTRA V6 in forum Engine & Drivetrain
    Last Post: 13th December 2006, 22:20
