Thread: best way too clean a k@n filter?
    Regular Member pogo's Avatar
    Feb 2006
    Vehicle : Insignia
    Trim : Sri
    Engine : 2.0 turbo petrol
    Year : 2010
    Default best way too clean a k@n filter?
    ive got a used but ok k@n panel filter and im going too fit in the beast but it needs cleaned so my stupid question is this can i jetwash it? carefully of course, too remove crud from it also has anyone drilled their airbox and acheived a good result?
    On a Sabbatical daviek's Avatar
    ayrshire scotland
    Better using a engine cleaner like Jizer diluted a bit or the actual K&N cleaner , then you'll need to leave till fully dry and re-oil it. Jetwash wouldnt clean it very good . Leave it soak overnight in a basin
    Regular Member ANDY W's Avatar
    May 2007
    WINSFORD
    Buy the K&N Cleaner Kit as it comes with the cleaner, new filter oil and full instructions and for a tenner its worth every penny. Its also worth giving the filter a good tap with the dirty side down as loads of muck likes flies etc comes out of them.
    Regular Member arnie_barney's Avatar
    Nov 2007
    Omagh, Co.Tyrone, N.Ireland
    Definately do not power wash it as the powerwasher will put holes in the fabric within the filter. If it is really bad use an air line at about 2ft away to blow away most of the crap and then wash it in basin or sink using warm water and a small amout of handwash clothes detergent (bold, daz etc) and let it soak. After soaking and cleaning let it dry and then re-oil it.
    Hanging Heaton / Batley
    14 Post(s)
    Trim : SRi (VXR Styling)
    Engine : Z19DTH (Re-mapped)
    Mileage : 110k
    Dont drill the box mate... did it on my astra and felt more sluggish, i only did the lower tray part wing side - so the coldest too, had to buy a new box in the end.
  1. changin oil, oil filter air filter and plugs any handy tips!!
    By wallace78 in forum Engine & Drivetrain
    Last Post: 5th February 2011, 15:04
  2. How often do you clean your K&N FILTER
    By Diesel Dude in forum Vectra C / Signum Car Chat
    Last Post: 27th January 2011, 18:20
  3. Spark plug change? K&N filter clean?
    Last Post: 11th January 2010, 22:15
