Wow it's been nearly a year since we've had the net, dunno how i've managed to get by without having the net for so long I still have that lindam gate if you still need it duncan
I'd also like to say that since the body control module and column intigration module packed up we've had no issues at all in virtually a years worth of driving (touch wood)
Right, we have a bit cash atm and the car is needing a few things doing to it for it's upcoming mot. Tie rod's, new discs/pads etc - i also managed to wangle in the excuse that the shocks are worn and the spring needs replacing on drivers side, therefore a suspension kit is needed, she took it hook line and sinker
I've seen some alloys for a good price, although the style is not exactly amazingly eye catching, there at a great price with tyres and anything is better than wheel trims. Am i right in assuming that they will be a straight fit?
Rim Diameter: 18"
Rim Width: 8J
Offset: 45
Number of Studs: 5
Stud Diameter: 110
Will these will go on ok with a 45mm drop aswell? Tyres will be 225/40ZR18
Regards,
Simon.
